Home Assistant Voice PE - Suddenly Stopped Working
Hi all,
As the title says, my Voice Assistant PE just suddenly stopped working this afternoon showing a spinning red ring on the LED display.
Tried rebooting the device and HA but no luck. Have then wiped and reinstalled the firmware however it is not being auto discovered and when I try and configure it manually I get the error below:
Unable to connect to the ESPHome device. Make sure the device’s YAML configuration includes an api section.
When monitoring the logs, I can also see it connecting and disconnecting from my WiFi.
15:49:41][I][wifi:617]: WiFi Connected!
[15:49:41][C][wifi:433]: SSID: ‘‘[redacted]
[15:49:41][C][wifi:441]: Hostname: ‘home-assistant-voice-09cf17’
[15:49:41][C][wifi:443]: Signal strength: -51 dB ▂▄▆█
[15:49:41][C][wifi:447]: Channel: 7
15:49:50][W][wifi_esp32:711]: Event: Disconnected ssid=’
’ reason=‘Beacon Timeout’
Any ideas anyone? It was working perfectly up until today.
Okay I have managed to resolve my issue. I had a look through my router logs and noticed it was my router that was constantly disconnecting the Voice Assistant. I resolved this by disabling Roaming Assistant on my router (ASUS RT-AX82U).
