I have two Home Assistant Voice PE hardware devices, one in the kitchen and one in the living room. I use these to playback music with Music Assistant running on Home Assistant on a Raspberry Pi. One I call ‘Jarvis’ and the other ‘Nabu’ and I use separate wake words for each ‘Hey Jarvis’ and ‘OK Nabu’.
I use a couple of automations for the voice commands. When I give a voice command the Voice PE will respond with the format ‘song_name playing on mass_player_name’, for example it would say ‘Nothings Shocking playing on Jarvis’ and then play the song.
This has worked well, however, I haven’t used it for a few months and restarted Home Assistant and updated everything today.
It is now responding with ‘Nothings Shocking playing on Jarvis favourite current song Jarvis’ and then plays the song.
How can I stop it including the extra ‘favourite current song Jarvis’ as this is annoying?
I know that one of the updates to Music Assistant introduced a ‘favourite current song’ button which seems to be included in ‘mass_player_name’.
In case it is useful the voice response in my automation is set by the following:
response_input:
name: Response for Assist
description: The response which will be given by Assist.
selector:
text:
multiline: false
multiple: false
default: '{{ ''Shuffling'' if ''shuffle'' in trigger.sentence | lower else
''''}} {{ trigger.slots.media_name }} {{ '''' if ''shuffle'' in trigger.sentence
| lower else ''playing''}} on {{ mass_player_name }}'
Thanks for your help!
