Home Assistant Voice PE won't compile
This device was working properly after initial installation but when initiating an update that that was indicated in ESPHome Builder, the file failed to compile. I have made many attempts to compile in ESPHome Builder and using VS. The ESPHome version is up to date both in HA and on my Windows laptop. The errors seemingly change and at one point the file did finish compiling and installing but the device was unresponsive following the ‘successful install.’
I have subsequently restored the device to factory settings, reloaded ESPHome firmware from the ESPHome web installer, and accepted the new discovery in HA. While everything seems to work within HA as far as changing settings etc., the device no longer responds to voice, no longer displays any lights, and does not respond to the button push. Trying to compile and install the file from ESPHome fails with multiple files apparently missing.
The log file text:
INFO ESPHome 2025.4.1
INFO Reading configuration /config/esphome/home-assistant-voice-09996b.yaml...
INFO Updating https://github.com/esphome/home-assistant-voice-pe@dev
WARNING GPIO0 is a strapping PIN and should only be used for I/O with care.
Attaching external pullup/down resistors to strapping pins can cause unexpected failures.
See https://esphome.io/guides/faq.html#why-am-i-getting-a-warning-about-strapping-pins
WARNING GPIO3 is a strapping PIN and should only be used for I/O with care.
WARNING GPIO45 is a strapping PIN and should only be used for I/O with care.
INFO Generating C++ source...
INFO Updating https://github.com/espressif/[email protected]
INFO Compiling app...
Processing home-assistant-voice-09996b (board: esp32-s3-devkitc-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32.git#51.03.07)
HARDWARE: ESP32S3 240MHz, 320KB RAM, 8MB Flash
 - framework-espidf @ 3.50105.0 (5.1.5)
 - tool-cmake @ 3.21.3
 - tool-esptoolpy @ 4.8.1
 - tool-mklittlefs @ 3.2.0
 - tool-ninja @ 1.10.2
 - tool-riscv32-esp-elf-gdb @ 12.1.0+20221002
 - tool-xtensa-esp-elf-gdb @ 12.1.0+20221002
 - toolchain-esp32ulp @ 2.35.0-20220830
 - toolchain-riscv32-esp @ 12.2.0+20230208
 - toolchain-xtensa-esp32s3 @ 12.2.0+20230208
Reading CMake configuration...
Dependency Graph
|-- esp-audio-libs @ 1.1.3
|-- noise-c @ 0.1.6
|-- ESPMicroSpeechFeatures @ 1.1.0
Compiling .pioenvs/home-assistant-voice-09996b/src/main.cpp.o
In file included from src/esphome/components/i2s_audio/i2s_audio.h:5,
                 from src/esphome.h:44,
                 from src/main.cpp:3:
/data/cache/platformio/packages/framework-espidf/components/driver/deprecated/driver/i2s.h:27:2: warning: #warning "This set of I2S APIs has been deprecated, please include 'driver/i2s_std.h', 'driver/i2s_pdm.h' or 'driver/i2s_tdm.h' instead. if you want to keep using the old APIs and ignore this warning, you can enable 'Suppress leagcy driver deprecated warning' option under 'I2S Configuration' menu in Kconfig" [-Wcpp]
   27 | #warning "This set of I2S APIs has been deprecated, \
In file included from components/esp-tflite-micro/tensorflow/lite/micro/tflite_bridge/flatbuffer_conversions_bridge.h:19,
                 from components/esp-tflite-micro/tensorflow/lite/micro/micro_allocator.h:26,
                 from components/esp-tflite-micro/tensorflow/lite/micro/micro_interpreter.h:26,
                 from src/esphome/components/micro_wake_word/streaming_model.h:10,
                 from src/esphome/components/micro_wake_word/micro_wake_word.h:6,
                 from src/esphome.h:70:
components/esp-tflite-micro/tensorflow/lite/core/api/flatbuffer_conversions.h: In member function 'T* tflite::BuiltinDataAllocator::AllocatePOD()':
components/esp-tflite-micro/tensorflow/lite/core/api/flatbuffer_conversions.h:46:24: warning: 'template<class _Tp> struct std::is_pod' is deprecated: use is_standard_layout && is_trivial instead [-Wdeprecated-declarations]
   46 |     static_assert(std::is_pod<T>::value, "Builtin data structure must be POD.");
In file included from /data/cache/platformio/packages/toolchain-xtensa-esp32s3/xtensa-esp32s3-elf/include/c++/12.2.0/bits/char_traits.h:42,
                 from /data/cache/platformio/packages/toolchain-xtensa-esp32s3/xtensa-esp32s3-elf/include/c++/12.2.0/string:40,
                 from src/esphome/core/hal.h:2,
                 from src/esphome/components/audio_dac/audio_dac.h:4,
                 from src/esphome/components/aic3204/aic3204.h:3,
                 from src/esphome.h:3:
/data/cache/platformio/packages/toolchain-xtensa-esp32s3/xtensa-esp32s3-elf/include/c++/12.2.0/type_traits:757:5: note: declared here
  757 |     is_pod
xtensa-esp32s3-elf-g++: fatal error: Killed signal terminated program cc1plus
compilation terminated.
*** [.pioenvs/home-assistant-voice-09996b/src/main.cpp.o] Error 1
========================= [FAILED] Took 46.91 seconds =========================
Update: NabuCasa has a support website that allows reinstalling the Voice PE firmware. ( Home Assistant Voice PE I performed the reinstallation and the Voice PE was revived. At the termination of the firmware reinstall, the system asked about updating the device to which I acceded. Once again, the file failed to compile. On examination, I see that the firmware version currently loaded on the Voice PE is 2025.3.3. Any attempt to compile the either 2025.4.1 or 2025.4.2 ends in failure. Compiling either under ESPHome Builder or under Windows using VS always fails.
Same issue here.
This may or may not work as I had similar issues with my home built voice based on an esp32 s3.
Try the latest beta version of esphome 2025.5.xx it compiled fine on that for me.
Same issue for me, I don’t understand why :frowning:
2025-05-22 13:07:26,031 INFO Running command 'esphome --dashboard compile /config/esphome/home-assistant-voice-095c7b.yaml'
2025-05-22 13:08:13,832 INFO Process exited with return code 1
INFO ESPHome 2025.5.0
INFO Reading configuration /config/esphome/home-assistant-voice-095c7b.yaml...
Processing home-assistant-voice-095c7b (board: esp32-s3-devkitc-1; framework: espidf; platform: https://github.com/pioarduino/platform-espressif32.git#51.03.07)
 - framework-espidf @ 3.50106.0 (5.1.6)
 - tool-ninja @ 1.7.1
Dependency Graph
|-- esp-audio-libs @ 1.1.4
|-- noise-c @ 0.1.6
Compiling .pioenvs/home-assistant-voice-095c7b/src/esphome/components/api/api_connection.cpp.o
Compiling .pioenvs/home-assistant-voice-095c7b/src/esphome/components/api/list_entities.cpp.o
Compiling .pioenvs/home-assistant-voice-095c7b/src/esphome/components/api/proto.cpp.o
Compiling .pioenvs/home-assistant-voice-095c7b/src/esphome/components/api/subscribe_state.cpp.o
*** [.pioenvs/home-assistant-voice-095c7b/src/esphome/components/api/api_connection.cpp.o] Error 1
========================= [FAILED] Took 10.71 seconds =========================
The same here
Same issue for me
I am not using the PE but had the same issue with voice on my S3 board.I deleted the contents of the esphome/config/.esphome/platformio folder and tried again. Sorted it for me.
I read it somewhere I can’t find now but there is PR for it out there.
