I recently acquired the Home Assistant Voice Preview Edition and it everything works as intended. Now I want to have the voice output on my main audio system. I get the voice output, when I plug in a speaker into the output jack, but I want to use the Bose system that is in my network.
Where do I configure that?
Hi, I have the same issue the HA Voice plays on a regular speaker, however when I connect it into the Sonos 5 (3.5mm line in) no sound, the Sonos recognises the connection but nothing, did you find a solution?
Maybe I was a bit unclear in my question - plugging in a speaker in the 3.5mm line in is working all the time, but I want the system to respond via my Bose speaker, which is connected via Bluetooth to my HA server and is available as device and entity.
