Hi everyone,
I want to share my project with my VPE.
The display shows the current time and the outside temperature, the temperature of the hot water and the production of the PV.
This is my first post here so I will try to upload the STL files of my case. If you can give me a hint how to do this please ![]()
edit: https://www.thingiverse.com/thing:6926739
The internal speaker is in the case and the case is not completely closed to give the speaker a chance ![]()
The yaml code for the display and the sensors:
I also added 2 sensors to show me the stt text and the tts text of the VPE to fine tune my custom sentences to get better results:
substitutions:
friendly_name: Voice1
packages:
Nabu Casa.Home Assistant Voice PE: github://esphome/home-assistant-voice-pe/home-assistant-voice.yaml
esphome:
name_add_mac_suffix: false
friendly_name: ${friendly_name}
api:
encryption:
key: xxxxxxxx=
wifi:
ssid: !secret wifi_ssid
text_sensor:
voice_assistant:
on_stt_end:
- text_sensor.template.publish:
state: !lambda 'return x;'
on_tts_start:
time:
- platform: homeassistant
entity_id: sensor.lumi_lumi_weather_temperature_2
internal: true
entity_id: sensor.wetter_temperature_average
internal: true
entity_id: sensor.warmwasser_temperatur_2
internal: true
entity_id: sensor.pv_produktion_gesamt
internal: true
font:
- file: 'digital-7.ttf'
- file: 'BebasNeue-Regular.ttf'
image:
- file: mdi:water-thermometer-outline
resize: 30x30
- file: mdi:solar-power-variant
resize: 30x30
- file: mdi:sun-thermometer-outline
resize: 30x30
spi:
clk_pin: GPIO40 # (SCK/CLK)
mosi_pin: GPIO41 # (SDA)
display:
- platform: ili9xxx
model: ST7735
dc_pin: GPIO01
cs_pin: GPIO48
reset_pin: GPIO42
invert_colors: false
rotation: 90
dimensions:
height: 160
width: 128
offset_width: 0
offset_height: 0
pages:
- id: page1
lambda: |-
// Print time in HH:MM format
it.strftime(80, 0, id(font80), TextAlign::TOP_CENTER, "%H:%M", id(esptime).now());
it.image(0, 88, id(outtemp_icon));
// Print outside temperature (from homeassistant sensor)
if (id(outside_temperature).has_state()) {
it.printf(160, 70, id(font60), TextAlign::TOP_RIGHT , "%.1f°", id(outside_temperature).state); // Celsius als Text
- id: page2
lambda: |-
it.image(0, 88, id(warmwasser_icon));
// Print Warmwasser-Temperatur (from homeassistant sensor)
if (id(warmwasser_temperature).has_state()) {
it.printf(160, 70, id(font60), TextAlign::TOP_RIGHT , "%.1f°", id(warmwasser_temperature).state); // Celsius als Text
- id: page3
lambda: |-
it.image(0, 88, id(pv_icon));
// Print pv_produktion (from homeassistant sensor)
if (id(pv_produktion).has_state()) {
it.printf(160, 75, id(font50), TextAlign::TOP_RIGHT , "%.0f W", id(pv_produktion).state); // Celsius als Text
# Define the GPIO pin for controlling the display backlight
output:
- platform: gpio
id: display_backlight_output # Ändere den id-Namen für das output
pin: GPIO02 # Ändere den Pin auf den richtigen für dein Display
# Define a switch to control the backlight
switch:
- platform: output
name: "Display Backlight"
id: display_backlight_switch # Ändere den id-Namen für den switch
output: display_backlight_output
restore_mode: ALWAYS_ON
# For example cycle through pages on a timer
interval:
- interval: 5s
then:
- display.page.show_next: my_display
- component.update: my_display
