Hi Jack,
Thnx for you reply, I always connect locally via the IP-address I also scanned my network and the IP-address for HA hasn’t changed.
Via the Explorer I checked in the config folder the home-assistant.log file.
Connecting to the observer on port 4357 on the same IP-address is working just fine.
It says Supervisor Connected and System Healthy.
Also restarted the several times unfortunately no success.
Update:
Just looked at the HomeAssistant log again after a restart, could it be that a Component is causing this issue?
Perhaps someone can read the log and point me to a possible solution?
Homeassistant.log:
2025-06-06 10:03:19.780 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration lghorizon which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-06 10:03:19.782 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-06 10:03:19.784 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration eufy_security which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-06 10:03:19.785 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration bold which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-06 10:03:19.786 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-06 10:03:19.787 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration localtuya which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-06 10:03:19.788 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration sonoff which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2025-06-06 10:03:22.242 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //config/home-assistant_v2.db was shutdown cleanly
2025-06-06 10:03:22.276 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=459 from 2025-06-05 09:53:54.220937)
2025-06-06 10:03:27.170 WARNING (MainThread) [homeassistant.helpers.frame] Detected that custom integration 'sonoff' accesses hass.helpers.system_info, which should be updated to import functions used from system_info directly at custom_components/sonoff/system_health.py, line 60: info = await hass.helpers.system_info.async_get_system_info(). This will stop working in Home Assistant 2025.5, please create a bug report at https://github.com/AlexxIT/SonoffLAN/issues
2025-06-06 10:03:27.189 WARNING (MainThread) [homeassistant.util.loop] Detected blocking call to walk with args ('/config/custom_components/sonoff',) inside the event loop by custom integration 'sonoff' at custom_components/sonoff/core/const.py, line 33: for root, dirs, files in os.walk(path): (offender: /config/custom_components/sonoff/core/const.py, line 33: for root, dirs, files in os.walk(path):), please create a bug report at https://github.com/AlexxIT/SonoffLAN/issues
For developers, please see https://developers.home-assistant.io/docs/asyncio_blocking_operations/#walk
File "<frozen runpy>", line 198, in _run_module_as_main
File "<frozen runpy>", line 88, in _run_code
File "/usr/src/homeassistant/homeassistant/__main__.py", line 227, in <module>
sys.exit(main())
File "/usr/src/homeassistant/homeassistant/__main__.py", line 213, in main
exit_code = runner.run(runtime_conf)
File "/usr/src/homeassistant/homeassistant/runner.py", line 154, in run
return loop.run_until_complete(setup_and_run_hass(runtime_config))
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 712, in run_until_complete
self.run_forever()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 683, in run_forever
self._run_once()
File "/usr/local/lib/python3.13/asyncio/base_events.py", line 2040, in _run_once
handle._run()
File "/usr/local/lib/python3.13/asyncio/events.py", line 89, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in async_setup_component
result = await _async_setup_component(hass, domain, config)
File "/usr/src/homeassistant/homeassistant/setup.py", line 467, in _async_setup_component
await asyncio.gather(
File "/usr/src/homeassistant/homeassistant/setup.py", line 469, in <genexpr>
create_eager_task(
File "/usr/src/homeassistant/homeassistant/util/async_.py", line 45, in create_eager_task
return Task(coro, loop=loop, name=name, eager_start=True)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 896, in async_setup_locked
await self.async_setup(hass, integration=integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 662, in async_setup
await self.__async_setup_with_context(hass, integration)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 751, in __async_setup_with_context
result = await component.async_setup_entry(hass, self)
File "/config/custom_components/sonoff/__init__.py", line 185, in async_setup_entry
await system_health.setup_debug(hass, _LOGGER)
File "/config/custom_components/sonoff/system_health.py", line 61, in setup_debug
info[DOMAIN + "_version"] = f"{integration.version} ({source_hash()})"
File "/config/custom_components/sonoff/core/const.py", line 33, in source_hash
