Home Assistant without a local Hub
Hi all, I’m new to Home Assistant, but am working on a project to control devices (Ecobee, etc) that already provide a cloud based API to communicate without the need of going through a hub in the home. Longer term we would support a hub, but not needed at this point. I’m wondering if this software is setup to support managing strictly cloud based devices (and all of the workflow/automation that is built in) via a server somewhere else without the need for running on a hub in the home.
You can use command line sensors and switches etc. Then you can use curl to get or set the values for these devices.
