Home Assistant Yellow running 10 minutes fast
My Home Assistant Yellow has it’s time set to ~13 minutes ahead of real time.
No amount of rebooting helps, and I can’t see any reference to NTP in the logs, but I guess it has to be a p problem with NTP on the host.
Using the Terminal/SSH add-on I can only access a container shell which has no ability to see the host’s NTP settings, or access the RTC, and it also has no permissions to set the time manually.
How do I debug and fix this? I’m comfortable with accessing the host shell, if I can get access to it, but since the Yellow is an ‘appliance’ I’d have hoped that wouldn’t be necessary.
I’m seeing very similar here. If I do an action, it happens ‘in 11 minutes’, but Ive been unable to find anything helpful in terms of getting this fixed (and a lot of snippy replies about time zones being wrong!). Home Assistant Yellow, all up to date as of the time of writing.
Does anyone have any helpful guidance for this? I too am comfortable will shell access etc, but can’t find anything that is helping, as dsample has mentioned above.
Hi
Have you found a solution to this problem?
Hi Found it chrony add-in synch it perfect
