I just got my HA Yellow yesterday and I’m trying to get Zigbee working.
Out of the box I’m having issues.
I’m getting a warning and an error from ZHA. I’ve tried rebooting, disabling, enabling the ZHA Integration etc.
I also tried to enable multiprotocoll so it also supports Thread, but that didn’t work either. (Maybe I clicked that first and it flashed the radio once and now I can’t flash it back?)
When trying to flash Flash Silicon Labs radio firmware manually · NabuCasa/silabs-firmware Wiki · GitHub
I also get an error. when it gets to probing EZSP it errors out with “failed to probe running application type”
Flash error: https://i.imgur.com/bs5rMM1.png
Also GitHub - NabuCasa/silabs-firmware: Silicon Labs firmware for Yellow and SkyConnect has so many firmwares which one is the right one to chose?
Error:
Logger: homeassistant.config_entries
Source: components/zha/core/gateway.py:174
First occurred: 7:30:26 PM (1 occurrences)
Last logged: 7:30:26 PM
Error setting up entry Yellow Multi-PAN for zha
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 456, in wait_for
return fut.result()
asyncio.exceptions.CancelledError
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 382, in async_setup
result = await component.async_setup_entry(hass, self)
File "/usr/src/homeassistant/homeassistant/components/zha/__init__.py", line 111, in async_setup_entry
await zha_gateway.async_initialize()
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 189, in async_initialize
raise exc
File "/usr/src/homeassistant/homeassistant/components/zha/core/gateway.py", line 174, in async_initialize
self.application_controller = await app_controller_cls.new(
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 169, in new
await app.startup(auto_form=auto_form)
File "/usr/local/lib/python3.10/site-packages/zigpy/application.py", line 145, in startup
await self.connect()
File "/usr/local/lib/python3.10/site-packages/bellows/zigbee/application.py", line 124, in connect
self._ezsp = await bellows.ezsp.EZSP.initialize(self.config)
File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 104, in initialize
await ezsp._startup_reset()
File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 95, in _startup_reset
await self.reset()
File "/usr/local/lib/python3.10/site-packages/bellows/ezsp/__init__.py", line 124, in reset
await self._gw.reset()
File "/usr/local/lib/python3.10/site-packages/bellows/uart.py", line 258, in reset
return await asyncio.wait_for(self._reset_future, timeout=RESET_TIMEOUT)
File "/usr/local/lib/python3.10/asyncio/tasks.py", line 458, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
Warning:
Logger: homeassistant.components.zha.core.gateway
Integration: Zigbee Home Automation (documentation, issues)
First occurred: 7:30:09 PM (3 occurrences)
Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 1 of 3)
Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 2 of 3)
Couldn't start EZSP = Silicon Labs EmberZNet protocol: Elelabs, HUSBZB-1, Telegesis coordinator (attempt 3 of 3)
return fut.result()
await self.reset()
