I have been trying to set up a docker container with home-assistant-zwave-js-ui to talk with my Z-Stick Gen5 (ZW090) - UZB.
I have tried to use serial/by-id/ and also the direct path to the USB device but each time in the logs I get serial port closed unexpectedly. Here is the extract from the logs, I find it interesting it references ZW0100 but udevadm info shows it as a “Aeotec Z-Stick Gen5 (ZW090) - UZB” Could it also be a firmware issue on the stick as its quite old ? Checked in the UI and the path is right anyone have any ideas ?
At least one network key for S2 configured, enabling S2 security manager...
driver ready
Checking for configuration updates...
[Node 001] The node is alive.
[Node 001] The node is ready to be used
[Node 002] Beginning interview - last completed stage: ProtocolInfo
CNTRLR » [Node 002] pinging the node...
SERIAL » 0x010800130201002501c3 (10 bytes)
DRIVER » [Node 002] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 1
└─[NoOperationCC]
SERIAL « [ACK] (0x06)
SERIAL « 0x0104011301e8 (6 bytes)
SERIAL » [ACK] (0x06)
DRIVER « [RES] [SendData]
was sent: true
DRIVER No configuration update available...
DRIVER Serial port errored: The serial port closed unexpectedly! (ZW0100)
DRIVER destroying driver instance...
DRIVER driver instance destroyed
