Home automation and Rfxtrx
Hi all :slight_smile:
I installed the last version of Home Assistant 0.53.1 on Ubuntu with the Rfxtrx ext2.
Everything went well with the installation. When i start the webbrowser there are incoming sensors (for now only temp sensors). In the configuration > Customization tab i will give them a friendly name. That works okay.
But if I reboot or restart the service from home assistant and he checks the sensors, the sensors are found again but without friendly name. When i check the id’s from the sensors it changed to other numbers:
sensor.0a520704b80e8005370160_temperature:
friendly_name: Temp Koelkast
after restart services
sensor.0a520702b80e8008410160_temperature:
In the configuration file i set the folowing settings:
platform: rfxtrx
automatic_add: True
How i can i solve this issue? Do i have to add something in the configuration file?
Python release (python3 --version):
Python 3.5.2
Component/platform:
RFX
Have you added the sensor to your config file as described in the documentation ?
I did now, but how come the ID doesnt change now after a restart of the service?
If you want to change the entity ID itself, you need to name the device in your sensor section - for example:
  platform: rfxtrx
  devices:
    XXXXXXXXXX:
Where XXXXXXXXXX is the ID you detected using automatic_add.
The friendly_name in customize.yaml is used for the GUI but not the actual entity name itself.
I’ve got a blog post on the subject that might help - it gives a worked through example of an Oregon Scientific weather sensor.
tnx for your reply:) it works now :smiley: i think in the future i will make a step to zwave. The rfxtrx protocol seems a little bit old and i miss the 2 way communication.
I think the 433MHz devices have their place - they’re usually a lot cheaper than Z-Wave for a start, and there are devices available that don’t have Z-Wave equivalents. Given a choice I’d use Z-Wave throughout as well, but the beauty of HA is I don’t have to choose :slight_smile:
