I want to start my Bosch dishwasher in an automation using the program that was set on the appliance. I have only found the option to start a fixed program.
Some time ago I had an IFTTT applet that could start the appliance without changing the program. So I believe the API supports that (assuming IFTTT uses the same API).
What ways are there to achieve this? Any thoughts on this are appreciated.
This select entity shows which program is selected on my dishwasher:
You could get the value of this and start the appropriate program in an automation.
If I turn this switch on, the dishwasher starts using the program in the above select entity, so probably no need to check, just start using this switch
I found an action called Home Connect: Start dishwasher program, but it requires a Program as a mandatory argument. Even if I could use the dishwasher’s Selected Program entity here, I don’t see any way to pass along the additional options (such as “Extra Rinse”) that were selected directly on the dishwasher.
So, is there really no straightforward way to start the dishwasher while preserving the selected program and its options?
Unfortunately the API doesn’t expose any functionality that allows to start the already selected program. We talked with the Home Connect guys that work on the public API and we requested functionalities like this one. Unfortunately, there haven’t been any updates or confirmation regarding these changes.
So the way to go by the moment the one that @hertz suggested already, but it becomes complex and difficult when you want to include the program options that have been already set…
I’ve been able to set Affects to to Active program and then setting the Program to the desired program.
It looks like you can’t set the Dishwasher options like Start in relative - this returns an error saying it’s not supported. But I’ve been able to do what I want - thanks!
Hey there!
Idk if someone stills have this problem, but I just found a solution that works for me
You can completely bypass this bug by using the home_connect.set_program_and_options action directly on the active_program.
Here is the YAML snippet to start the wash:
# 1. Turn on the dishwasher
- type: turn_on
device_id: YOUR_DISHWASHER_DEVICE_ID
entity_id: switch.YOUR_DISHWASHER_POWER_SWITCH
domain: switch
# 2. Bypass the bug and start the program directly
- action: home_connect.set_program_and_options
affects_to: active_program
program: dishcare_dishwasher_program_night_wash
