Home Connect: Error handling request
Hello, I’ve tried to add my Bosch dishwasher to HA using Home Connect integration. I did all the steps according to the integration instructions (Home Connect - Home Assistant) and then tried to add the intergration. I log in the account and approve permissions, after that I get " 500 Internal Server Error: Server got itself in trouble"
What is going wrong? This is what shows in my logs:
Logger: aiohttp.server
Source: helpers/config_entry_oauth2_flow.py:201
First occurred: 1:20:55 PM (2 occurrences)
Last logged: 1:21:09 PM
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 422, in _handle_request
    resp = await self._request_handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_app.py", line 499, in _handle
    resp = await handler(request)
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_middlewares.py", line 119, in impl
    return await handler(request)
  File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 60, in security_filter_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 98, in forwarded_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 24, in request_context_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 78, in ban_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 138, in auth_middleware
  File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 135, in handle
    result = await result
  File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 148, in get
    return await super().get(request, flow_id)
  File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 96, in get
    result = await self._flow_mgr.async_configure(flow_id)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 246, in async_configure
    result = await self._async_handle_step(flow, cur_step["step_id"], user_input)
  File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 320, in _async_handle_step
    result: FlowResult = await getattr(flow, method)(user_input)
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 293, in async_step_creation
    token = await self.flow_impl.async_resolve_external_data(self.external_data)
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 165, in async_resolve_external_data
    return await self._token_request(
  File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 201, in _token_request
    resp.raise_for_status()
  File "/usr/local/lib/python3.9/site-packages/aiohttp/client_reqrep.py", line 1000, in raise_for_status
    raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request', url=URL('https://api.home-connect.com/security/oauth/token')
Hi sgaluf
I have the same Problem. Have you fix ist?
Unfortunately not. Just tried it on different devices and browsers, and it still doesn’t work…
