Dear all, I have a problem with integrate integration Home Connect Local from HACS. I get this error
ERROR
Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble
I have downloaded the last version, I resolved the issue with the add-on developer, but the issue was closed as an HA issue.
From the Core log it is clear that there is probably a problem with DNS, because the necessary package is not downloaded.
HA I have HAOS on x86-64, network settings as automatic DHCP, there is no problem in other integrations.
I have cleaned the entire HA, it only has the most necessary addons and integrations. I have no idea where the problem could be.
Zde je CORE log:
Logger: homeassistant
Source: requirements.py:292
First occurred: April 13, 2025 at 20:43:10 (48 occurrences)
Last logged: 12:07:23
Error doing job: Task exception was never retrieved (None)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1455, in async_init
flow, result = await self._async_init(flow_id, handler, context, data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1480, in _async_init
flow = await self.async_create_flow(handler, context=context, data=data)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 1698, in async_create_flow
handler = await _async_get_flow_handler(
self.hass, handler_key, self._hass_config
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3790, in _async_get_flow_handler
await _load_integration(hass, domain, hass_config)
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 3767, in _load_integration
await async_process_deps_reqs(hass, hass_config, integration)
File "/usr/src/homeassistant/homeassistant/setup.py", line 581, in async_process_deps_reqs
await requirements.async_get_integration_with_requirements(
hass, integration.domain
File "/usr/src/homeassistant/homeassistant/requirements.py", line 54, in async_get_integration_with_requirements
return await manager.async_get_integration_with_requirements(domain)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 170, in async_get_integration_with_requirements
await future
File "/usr/src/homeassistant/homeassistant/requirements.py", line 159, in async_get_integration_with_requirements
await self._async_process_integration(integration, done)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 182, in _async_process_integration
await self.async_process_requirements(
integration.domain, integration.requirements
File "/usr/src/homeassistant/homeassistant/requirements.py", line 264, in async_process_requirements
self._raise_for_failed_requirements(name, missing)
File "/usr/src/homeassistant/homeassistant/requirements.py", line 292, in _raise_for_failed_requirements
raise RequirementsNotFound(integration, [req])
homeassistant.requirements.RequirementsNotFound: Requirements for homeconnect_ws not found: ['homeconnect-websocket==1.3.0'].
