Hi all,
I have a new dish washer which comes with smart home stuff. It’s by Siemens, so the integration would be “Home Connect”.
I go to my Home Assistant, add the Home Connect integration. I’m then forwarded to https://api.home-connect.com/security/oauth/authorize?...
and I’m asked for my email address, then forwarded to a page that asks for my password (https://singlekey-id.com/auth/...
). I click on “Login”, agree that HA may access all my data. Then I’m seeing “Link account to Home Assistant” on https://my.home-assistant.io/redirect/oauth/...
which is correctly showing my local HA address ("Your instance: http://homeassistant.local:8123
"). Here, I click on “Link account”, I’m forwarded to http://homeassistant.local:8123/config/integrations
, which displays a popup that says “Error” and nothing else
The error log is showing this entry:
Protokolldetails (FEHLER)
Logger: aiohttp.server
Source: helpers/config_entry_oauth2_flow.py:209
First occurred: 7. Mai 2023 um 18:02:54 (8 occurrences)
Last logged: 06:54:41
Error handling request
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_protocol.py", line 433, in _handle_request
resp = await request_handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_app.py", line 504, in _handle
resp = await handler(request)
File "/usr/local/lib/python3.10/site-packages/aiohttp/web_middlewares.py", line 117, in impl
return await handler(request)
File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 85, in security_filter_middleware
File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 100, in forwarded_middleware
File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 28, in request_context_middleware
File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 80, in ban_middleware
File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 235, in auth_middleware
File "/usr/src/homeassistant/homeassistant/components/http/view.py", line 146, in handle
result = await result
File "/usr/src/homeassistant/homeassistant/components/config/config_entries.py", line 171, in get
return await super().get(request, flow_id)
File "/usr/src/homeassistant/homeassistant/helpers/data_entry_flow.py", line 96, in get
result = await self._flow_mgr.async_configure(flow_id)
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 271, in async_configure
result = await self._async_handle_step(
File "/usr/src/homeassistant/homeassistant/data_entry_flow.py", line 367, in _async_handle_step
result: FlowResult = await getattr(flow, method)(user_input)
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 315, in async_step_creation
token = await self.flow_impl.async_resolve_external_data(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 172, in async_resolve_external_data
return await self._token_request(
File "/usr/src/homeassistant/homeassistant/helpers/config_entry_oauth2_flow.py", line 209, in _token_request
resp.raise_for_status()
File "/usr/local/lib/python3.10/site-packages/aiohttp/client_reqrep.py", line 1005, in raise_for_status
raise ClientResponseError(
aiohttp.client_exceptions.ClientResponseError: 400, message='Bad Request', url=URL('https://api.home-connect.com/security/oauth/token')
Does anyone have an idea what is going on here?
