Is this the command needed to update the images when using docker-compose?
sudo docker-compose down
sudo docker pull timmo001/home-panel-api:latest
sudo docker pull timmo001/home-panel:latest
sudo docker-compose up -d
Or is there a better way?
any one know how can install it with hassbian?
All you have to do is cd into the directory of your docker-compose.yml file and do:
docker-compose pull && docker-compose up
You can install it using one of the other methods like this:
It seems Home Panel is referencing HA by hostname āhassioā rather than IP during authentication. Can I change that as my hostname is not āhassioā and it therefore fails.
Yes you can. Just change the text box to URL of your Home Assistant instanceā¦
Apologies that was a truly stupid question. I had changed the first text box and missed the second . It works thanks
What about adding icons to buttons? it can be as background or as a small icon on the lower right corner
How can I set default theme?
Thanks!
For the first point, I would recommend requesting the āDesktop siteā on your browser. Scaling is on mobile devices so this should force the page to render as a desktop with that resolution.
For the other points, these are already features. For icons, see here and for backgrounds and other theming configuration see here. The set theme is stored to your browser when you set it, so that will be your default
Thank you for replying.
Iāve tried the ādesktop versionā as you suggested, it does make things a bit better but the text is still huge.
I didnāt notice the icon option (!), now that Iāve added icons, it feels like the icons takes the focus. Is it possible to change their opacity and/or size?
Thank you !
Thanks a lot for this wonderful dashboard! Works really well for me (HassIO 0.77.3). Iām planning to allow access to my Home Panel via SSL (DuckDNS/Letās Encrypt) for my neighbour, so we can both switch our garden lights with HA.
Is my understanding correct, that anyone with access to the login screen of Home Panel can create a new user? If so, how can i prevent this? I just need two users and thatās it.
Thanks in advance!
This is a great dashboard!
Just one issue.
After a while, on a Fire 7th gen and Fully Kiosk Browser, the dashboard becomes very slow and sluggish.
It takes 5 - 10 seconds before a tile reacts to a touch.
Dumping the cache and a restart of the page solves it, but it really not WAF.
Thank you for developing this. Great panel! Im going to use this on a wall mounted panel but I canāt seem to find a way to have the panel auto login. Is there a way to do this so if the panel reboots I do t have to enter the password each time?
I have noticed this, however have no idea why it is happening. A refresh does usually fix the issue
Once it has logged in once, the login should be stored. It mostly depends on the token that is provided from Home Assistant and how long the token lasts
In this version, you can now add pages! Just add āpagesā to the same level as theme, header and items. See here for documentation. Also here for setting the groupās page.
Hopefully someone will find a solution for this. Itās a real dealbreaker for me.
I may have figured out what was causing slowdowns while on another PR. Take a look at the issue here:
Once I close this issue, and the next version is released, you should be OK to retry to see if you are still getting slowdowns. I will test this on my panel also once I get it set up again. Thanks for the pointer @PaNiCo
Great! Nice to see youāve found the cause.
Canāt wait to update.
I am running the hassio addon, does this also update as soon as you release #111?
