I just updated to 2023.3.5 and none of my home-based automations are working anymore. After the upgrade I got a notification about the county not being set and realized I couldn’t change anything in the general tab because it was configured in yaml. I commented out all of those settings and now the general tab works, however when I try to edit my location all I get is a blue house on an empty map. And HA says no one is home.
Any idea what’s going on here or how to fix it?
Edit… I uncommented the homeassistant: section in my yaml and now everything works. But of course, I cant use the general tab now. I’d like to remove that section of code from my config if possible so I’d still like to know how to fix it if anyone knows what to do.
Are you coming from an older release (skipped a few versions)?
Do you have any zones configured?
From my general tab, of course I have the settings in UI, at the bottom I can edit my location which brings me to zones.
I did come from a slightly older release. Late 2022.
No zones configured except maybe my home zone.
And I was able to get to the settings in the UI and even get to the spot to edit my location. But there’s just a blue house icon in a black empty square. I can zoom in and out but there are no streets or anything. And apparently there’s no location information either. Since my home status automations stopped working.
