Homeassistant 12h local weather forecast. ~94% accurate*
Issue was fixed, can you test it?
That works, thanks!
I think it should support both :grinning:
both pressure is supported
I’ve been using this HomeAssistant integration, and I can confirm it works really well for local weather forecasting. Having just a barometer is enough to get decent predictions, but adding extra sensors like temperature, humidity, or wind speed really boosts accuracy. I also like that it doesn’t rely on external APIs, so the forecasts stay stable and consistent. Definitely a handy tool for anyone into home automation!
when I will have time I would like to add support for humidity, and other sensor we will see
:sun_behind_small_cloud: New Info: Local Weather Forecast v3.1.0 Beta
Testing advanced forecasting features - feedback welcome!
:sparkles: Key Features
Advanced forecasting with 3-day daily + 6-hour hourly predictions, realistic temperature models, automatic day/night icons (sunrise/sunset), fog risk detection (humidity), atmospheric stability (wind gust), real-time rain override, and enhanced rain probability with confidence scoring.
Weather entity improvements:
  • 3-day daily forecast with temperature trends
  • 6-hour detailed hourly predictions
  • Smart day/night icons (automatic sunrise/sunset)
  • Realistic temperature curves using diurnal models
New sensor capabilities:
  • Humidity → Fog risk + dewpoint calculation
  • Wind gust → Atmospheric stability detection
  • Rain rate → Real-time 100% override when raining
  • Enhanced rain probability with confidence scores
:link: Try It
Branch: feature/extended-sensors
You can check live weather data and snow forecast at your area by entering zip code or city name at protonreader.com as well.
dik že si niečo taketo spravil prave som na podobnu vec tiež chystal
Im not seeing this in HACS. Is it called something different? Thanks!
Wait- What? In what world is a 12-hour forecast 94% accurate? OWM says it’s snowing at my location now, yet the sun is shining outside?
it is good question, but not for me :slight_smile: I only converted old yaml version to new integration with possibility merge forecast amd actual state from sensor to weather entity.
You need to add new repo manually
