I was working on the GUI yesterday and all was fine using the homeassistant:8123 url.
SInce then, I have rebooted my pi with hassio installed on it, and now the dns will not work. However, it will work if I use the pi ip address instead. I assumed my router may have assigned a different ip address so I ensured that this one was set as static. However, this has not fixed the issue with homeassistant:8123.
Is there something I need to change in the gui or vi ssh to get this working again?
I know I could continue with just the ip address locally but as I have a duckdns, I thought this may have a knock on effect.
this is a recurring problem for me after an upgrade. While I am able to access my homeassistant instance via my xxxx.duckdns.org URL it does not respond to the homeassistant.local:8123 or the IP address (I have assigned a static one). Usually it works after a couple or more of reboots but this time no…I went from version 0.11.4 to 0.12.2. there have been no changes to the router.
While it may eventually work is there an explanation to this? Is it something in my configuration that causes this? I would appreciate any help I can receive on this.
