After running smoothly for a year a update reboot broke my entire setup and now I am lost what to do.
Can’t ping any web address from HomeAssistant. No changes in my home network. Network configuration in Home Assistant either Automatic or Static with 8.8.8.8 make no change.
As a result all add-ons and integrations that use the Cloud are broken.
DNS
/command/s6-rmrf: line 1: syntax error: unexpected word (expecting ")")
s6-overlay-suexec: fatal: child failed with exit code 2
Supervisor
24-03-01 10:50:17 INFO (MainThread) [supervisor.docker.dns] Starting DNS ghcr.io/home-assistant/aarch64-hassio-dns with version 2023.06.2 - 172.30.32.3
24-03-01 10:50:17 ERROR (MainThread) [asyncio] Task exception was never retrieved
future: <Task finished name='Task-1126' coro=<PluginDns.watchdog_container() done, defined at /usr/src/supervisor/supervisor/plugins/dns.py:270> exception=CoreDNSJobError('Rate limit exceeded, more than 10 calls in 0:30:00')>
File "/usr/src/supervisor/supervisor/plugins/dns.py", line 275, in watchdog_container
return await super().watchdog_container(event)
File "/usr/src/supervisor/supervisor/plugins/base.py", line 109, in watchdog_container
await self._restart_after_problem(event.state)
File "/usr/src/supervisor/supervisor/jobs/decorator.py", line 290, in wrapper
raise on_condition(
supervisor.exceptions.CoreDNSJobError: Rate limit exceeded, more than 10 calls in 0:30:00
