since october 26 I´ve issues at recorder and statistics - now idea why. I already tried several backups - no success until now. I use Home Assistant 2023.10.3, Supervisor 2023.10.1, Operating System 11.1, Frontend 20231005.0 - latest, recorder at MariaDB and influxDB for longterm.
the energy view is empty since that day, or let´s say in the meantime it worked after some reboots for some hours but it´s not working now. many (but not all) sensors stopped the trend view also at that time, but opening “more” works perfect.
at the protocol I found these two entries:
Logger: homeassistant.components.recorder.util
Source: components/recorder/util.py:130
Integration: Recorder (documentation, issues)
First occurred: 15:20:13 (8 occurrences)
Last logged: 15:50:10
Error executing query: unsupported operand type(s) for +: 'NoneType' and 'float'
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 130, in session_scope
yield session
File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 454, in compile_missing_statistics
modified_statistic_ids = _compile_statistics(
File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 528, in _compile_statistics
compiled: PlatformCompiledStatistics = platform_compile_statistics(
File "/usr/src/homeassistant/homeassistant/components/sensor/recorder.py", line 462, in compile_statistics
last_stats = statistics.get_latest_short_term_statistics_with_session(
File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 1941, in get_latest_short_term_statistics_with_session
return _sorted_statistics_to_dict(
File "/usr/src/homeassistant/homeassistant/components/recorder/statistics.py", line 2110, in _sorted_statistics_to_dict
"end": start_ts + table_duration_seconds,
TypeError: unsupported operand type(s) for +: 'NoneType' and 'float'
=============== and ==========
Logger: homeassistant.components.recorder.core
Source: components/recorder/core.py:893
Error while processing event StatisticsTask(start=datetime.datetime(2023, 10, 28, 13, 25, tzinfo=datetime.timezone.utc), fire_events=True): unsupported operand type(s) for +: 'NoneType' and 'float'
Error while processing event StatisticsTask(start=datetime.datetime(2023, 10, 28, 13, 30, tzinfo=datetime.timezone.utc), fire_events=True): unsupported operand type(s) for +: 'NoneType' and 'float'
Error while processing event StatisticsTask(start=datetime.datetime(2023, 10, 28, 13, 35, tzinfo=datetime.timezone.utc), fire_events=True): unsupported operand type(s) for +: 'NoneType' and 'float'
Error while processing event StatisticsTask(start=datetime.datetime(2023, 10, 28, 13, 40, tzinfo=datetime.timezone.utc), fire_events=True): unsupported operand type(s) for +: 'NoneType' and 'float'
Error while processing event StatisticsTask(start=datetime.datetime(2023, 10, 28, 13, 45, tzinfo=datetime.timezone.utc), fire_events=True): unsupported operand type(s) for +: 'NoneType' and 'float'
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 893, in _guarded_process_one_task_or_recover
self._process_one_task_or_recover(task)
File "/usr/src/homeassistant/homeassistant/components/recorder/core.py", line 904, in _process_one_task_or_recover
return task.run(self)
File "/usr/src/homeassistant/homeassistant/components/recorder/tasks.py", line 177, in run
if statistics.compile_missing_statistics(instance):
File "/usr/src/homeassistant/homeassistant/components/recorder/util.py", line 609, in wrapper
return job(instance, *args, **kwargs)
I see there are issues with operand types but why did they happen and how can I solve this?
hopefully someone can support me - thanks a lot
