HomeAssistant delay when multicast ACK not received
I’m using zwave_js.multicast_set_value to turn 11 switches on in parallel. And it works great the first time the automation is triggered - all the light switches turn on immediately. All are ZWave+.
However sometimes the switches don’t report back, which causes a 15-20 second hang before HA will process any other zwave requests. Very annoying if we are coming home and need to turn on a few different switches!
alias: All Lights - 1x Normal Lighting (Multicast)
description: ''
  - platform: event
    event_type: zwave_js_value_notification
    event_data:
      node_id: 2
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 3
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 4
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 5
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 6
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 7
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 8
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 9
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 11
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 38
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 13
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 13
      label: Scene 005
      value: KeyPressed
  - platform: state
    entity_id: switch.light_switch_main_entrance
    to: 'on'
condition: []
  - service: zwave_js.multicast_set_value
      entity_id:
        - switch.light_switch_baby_room
        - switch.light_switch_baby_room_hallway
        - switch.light_switch_kitchen_lights
        - switch.light_switch_living_room_standing_lamp
        - switch.light_switch_main_entrance
        - switch.dining_table_lights
        - switch.living_room_plant_light
        - switch.bar_cart_light
        - switch.couch_lights
        - switch.tv_lights
        - switch.track_lights
      command_class: '37'
      property: targetValue
      value: true
mode: single
max: 10
I also tried a similar automation but using homeassistant.turn_on instead of zwave_js.multicast_set_value. This took about 20 seconds as well for all the lights to turn on, except in a staggered fashion – not all at once.
alias: All Lights - 1x Normal Lighting (Unicast)
description: ''
  - platform: event
    event_data:
      node_id: 2
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 3
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 4
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 5
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 6
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 7
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 8
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 9
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 11
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 38
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 13
      label: Scene 004
      value: KeyPressed
  - platform: event
    event_data:
      node_id: 13
      label: Scene 005
      value: KeyPressed
condition: []
  - service: homeassistant.turn_on
      entity_id:
        - switch.tv_lights
mode: single
max: 10
When the multicast query gets delayed, I see this in the logs:
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 381, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 584, in _async_call_service_step
    await service_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1495, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1530, in _execute_service
    await handler.job.target(service_call)
  File "/usr/src/homeassistant/homeassistant/components/zwave_js/services.py", line 509, in async_multicast_set_value
    success = await async_multicast_set_value(
  File "/usr/local/lib/python3.9/site-packages/zwave_js_server/util/multicast.py", line 54, in async_multicast_set_value
    result = await _async_send_command(
  File "/usr/local/lib/python3.9/site-packages/zwave_js_server/util/multicast.py", line 29, in _async_send_command
    return await client.async_send_command(cmd, require_schema)
  File "/usr/local/lib/python3.9/site-packages/zwave_js_server/client.py", line 79, in async_send_command
    return await future
zwave_js_server.exceptions.FailedZWaveCommand: Z-Wave error 202: One or more nodes did not respond to the multicast request (Status Fail) (ZW0202)
Since all the lights turn on w/ multicast, is there a way to force HA to move on and not wait for the ACKs? The delays are pretty annoying! Thanks in advance
