mkanet
(MKANET)
February 8, 2021, 5:52am
1
I am getting the below exception on all similar sensors when first starting up Home Assistant:
homeassistant.exceptions.TemplateError: TypeError: unsupported operand type(s) for /: 'NoneType' and 'int'
2021 - 02 - 07 21:19:00 ERROR (MainThread) [homeassistant.components.template.template_entity] TemplateError('TypeError: unsupported operand type(s) for /: 'NoneType' and 'int'') while processing template 'Template("{{ (state_attr('sensor.tautulli','lan_bandwidth') / 1000) | round(2) }}")' for attribute '_state' in entity 'sensor.tautulli_lan_bandwidth'
2021 - 02 - 07 21:19:00 ERROR (MainThread) [homeassistant.helpers.event] Error while processing template: Template("{{ (state_attr('sensor.tautulli','total_bandwidth') / 1000) | round(2) }}")
Code:
tautulli_lan_bandwidth:
friendly_name: 'LAN bandwidth'
value_template: "{{ (state_attr('sensor.tautulli','lan_bandwidth') / 1000) | round(2) }}"
unit_of_measurement: "Mbps"
Below, is my best attempt to avoid the exception. However, it doesn’t avoid the error.
{% if (lan_bandwidth != None ) %}
{% endif %}
availability_template: >-
{{ states("sensor.tautulli") not in ["unknown", "unavailable"] }}
tom_l
February 8, 2021, 6:22am
2
Assuming your sensor is good some time after the restart, your attribute lan_bandwidth
seems to be a number and normally would not require the | float
or | int
filter to convert it from a string to a number, but on start up it is likely to be none
, which can not be divided by 1000. Using the | float
or | int
filters will convert strings to 0
and stop the error occurring.
value_template: "{{ (state_attr('sensor.tautulli','lan_bandwidth') | float / 1000) | round(2) }}"
However this may put zeros in your data every restart so a better option might be to add an availability template instead:
availability_template: "{{ state_attr('sensor.tautulli','lan_bandwidth') is number }}"
or (you nearly had it but missed the ‘none’ case):
{{ states("sensor.tautulli") not in ["unknown", "unavailable", "none"] }}
EDIT: go with the second option. There seems to be something wrong with the is number
test:
EDIT2:
Actually it’s the template editor that has the issue. is number
works when the attribute is actually a number:
So you can use that test if you find it easier/cleaner.
I’ve opened an issue regarding the template editor.
opened 09:01AM - 08 Feb 21 UTC
The problem
The developer tools template editor is returning an incorrect type for attributes. e.g. From the developer tools states menu, sensor.json_lounge_aircon...
mkanet
(MKANET)
February 8, 2021, 9:52pm
3
Thank you. I want to be sure I understood correctly. My best option currently is to use the below code?
tom_l
February 9, 2021, 4:52am
4
You can use either solution.
