As i can’ use no more accumulation I switched to use heat pumps. Finally I choose ‘Fujitsu’ which works, but there are some items on it I don’t like at all.
Everybody proposes me to use HomeAssistant, but asking for help how to, it seems I live on an Island
I found some info about Fujitsu Airstage from @danielkaldheim, but I can find nowhere a real nice answer on my problems below
Can someone help me please .
AS IS
fujitsu Airstage
3 intrnal units AGEG 09 KVCA
1 WiFi-dongle for each unit UTY-TFSXJ3
Contra:
- temperature sensor is placed inside unit. This means always wrong measurment
- Units are placed against exterior walls, meaning that measured temperature differs from real roomtemperature
- Each 5 minutes, all units run for about 1 min to measure ‘real’ temperature. This generates a cold airstream
- If too cold, to warm the external Unit starts and the internal unit starts.
- The delta to start the units is too small, only 0.3°C
- Only 4 different timesettings
Whish:
- central placed wireless temperature sensors
- Greater delta before units starts
- Full control over ection units by the external sensors
- NO temperature-test every 5 minutes, no test at all
- Full control via homeassistant
Is this possible ?
What do I need as components ?
How setup homeassistant ?
