When I plug in my Home Assistant Green, all I get is the white LED. I have held the power button down to turn it off, unplugged it, waited for five minutes, and plugged it back in with an SD card, and still nothing. Keyboard does not get power, no HDMI output. I added a CR 2032 to no avail. I'm using the included power brick.
Edit- Additional details:
I have tried two four GB SD cards, each written and verified by Balena Etcher 2.1.6, using the latest release of the Green installer from Github, 20240410. It's plugged into ethernet, but the switch it is plugged into does not see it, or get any traffic from it when turned on.
Ok, I've reflashed the SD card, after cleaning it. I'm trying to give at least five minutes between unplugging and turning it on again, so I'll be back in a bit.
Can you try with another ethernet cable, another port and you do not happen to run any kind of networkwide blocking software like Pi-Hole, Adguard, ...
That switch you are connecting to, is it on the same logical network as all your other devices?
Yep, no Pi-Hole or other software. The Green is plugged in right next to the computer I'm posting from- it's a Unifi AP. I can see on the time it did power up, it connected to GitHub and downloaded ~360 MB. I'll move ports and get back to you.
Yep, I've had them plugged in for a while now- even making sure to wake the monitor up before turning the Green on. The keyboard has a back light for the keys, and I've only had the backlight come on the one time I got it to flash properly. I got video output then too, but nothing before or since.
