hello,
How do i get information like this in Homeassistant?
{“time”: “2025-03-13 16:24:39”, “model”: “Oregon-THN132N”, “id”: 83, “channel”: 1, “battery_ok”: 1, “temperature_C”: 23.4}
Dick
hello,
Dick
Provided that your device doesn’t support MQTT discovery, you will have to create an MQTT sensor manually, as explained here: MQTT Sensor - Home Assistant
THANKS
I use discovery with this command.
mqtt
discovery: true
I don’t see recognation of a sensor from
mqtt/ ttl43/pi or rtl433/pi2
Dick
Your device needs to explicitly support Home Assistant MQTT discovery.
thank again.
you are right, but now:
How do i do that?
Dick
sorry i forget the next infrmation
mqtt:
- name: “Temperature”
state_topic: “rl433/pi/temperature”
The device either supports it, or it doesn’t
It looks like you’re using rtl_433
, in which case you can look here: rtl_433/docs/INTEGRATION.md at da289d37eba7378726fcde502d38a466f9128b22 · merbanan/rtl_433 · GitHub
It doesn’t seem to support HA MQTT discovery, so you will have to add sensors manually.
ok
indeed i use rtl_433//pi
but there comes not any information about my sensors.
I use a p1-monitor and they gives that information ok.
thanks
Dick
I already explained multiple times that you will need to manually create an MQTT sensor for them.
Add this add-on
