[homeassistant.loader] BOOT WARNINGS with custom component: customizer, alarm_control_panel.bwalarm and emulated_roku
Hello, since the last update 0.73.0 i’m having this warnings during the boot process.
Any idea on how to fix this?
2018-07-08 07:29:39 WARNING (MainThread) [homeassistant.loader] You are using a custom component for customizer which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-07-08 07:29:41 WARNING (MainThread) [homeassistant.loader] You are using a custom component for alarm_control_panel.bwalarm which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
2018-07-08 07:29:41 WARNING (MainThread) [homeassistant.loader] You are using a custom component for emulated_roku which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you do experience issues with Home Assistant.
Thanks.
No fix. It jus a warning and plant it there on purpose.
Thank you for the answer.
