Homeassistant.local sent an invalid response
Hi…
I’m try to connect to download Home assistant on my Pi (I have a Pi 4 model B 2g ram 64-bit), I downloaded the 32-bit version on my micro SD card (32g), inserted it in my Pi and connected the Ethernet cable, after that powered it. When I try to go to this link: (https://homeassistant.local:8123)
it shows me that the site can’t provide a secure connection and it sends an invalid response or it shows ( homeassistant.local.8123 ’s server IP address could not be found.), do you have any idea why?
thank you
I’m having the same problem.
can you try http://ha_ip:8123
does the job, thank you
