HomeAssistant only external Access
HomeAssistant access is only available with the externen IP.
Either https://myip:8123 or
https://HomeAssistant.local:8123/lovelace are working anymore.
Any idea ?
thx
This is an english forum only as you might have noticed so please English.
Things like this never happen just-like-that…did you install /change something?
Then you need to be clear about your installation so people can help better, e.g. I know very little about supervised or hassio.
when you see -this connection is not private press extended and continue with -go to myip (unsave)
no. i get the Ha startup window with the message unable to connect to HA retrying in xx seconds
did you setup a proxy
did you change configuration.yaml eg. internal/external url?
what if you use http instead of https …
sorry two logins … is still me :wink:
I only have this entry
http:
    ssl_certificate: //ssl/fullchain.pem
    ssl_key: /ssl/privkey.pem
    cors_allowed_origins:
        https://google.com
        https://www.home-assistant.io
    ip_ban_enabled: true
    login_attempts_threshold: 5
no proxy
if I type in http it will automatically forward to https
Did you verify local ip is not banned?
where is that possible ?
how can I check it ?
You would have an ip_bans.yaml in your configuration directory.
IP address listed in the file will not be able to login
Delete file or delete individual IP and restart HA to allow banned IP to login again.
That makes sense.
but there is no file like that in the config dir !
I have a fixed IP
What about http://myip:8123
I come closer …
http://myip:8123 does not in Firefox ( Unable to connect to Home Assistant.Retrying in xx seconds)
but in Chrome I get “page not working”
if I change it there to https://myip:8123
i get “not secrure bla bla” but I can then follow the link and it is working !
So the problem is in Firefox and in the secure page setup
Any Idea ?
