Homeassistant push notifications via websocket
I developed an own frontend (react) and use homeassistant as backend.
At the moment I try to use the push notifications from homeassistant.
I found in the documentation a description, how to enable push notifications via websockets.
But I have problems to use this, because if I try to create the subscription via custom webhook_id I get the response “Webhook ID not found”.
Here is an simple python testscript to reproduce the behaviour.
Please help me to find my problem :slight_smile:
import asyncio
import websockets
import json
# Replace these with your Home Assistant details
HASS_URL = "ws://192.168.178.75:8123/api/websocket"
HASS_TOKEN = "my-hidden-token"
WEBHOOK_ID = "xyz"  # eindeutige ID für Push-Kanal
async def connect_to_hass():
    async with websockets.connect(HASS_URL) as websocket:
        # Initial message
        initial_message = await websocket.recv()
        print(f"Initial message: {initial_message}")
        # Authenticate
        auth_message = {"type": "auth", "access_token": HASS_TOKEN}
        await websocket.send(json.dumps(auth_message))
        auth_response = await websocket.recv()
        print(f"Auth response: {auth_response}")
        if json.loads(auth_response)["type"] == "auth_ok":
            print("✅ Successfully authenticated!")
            # Enable push notifications
            push_channel_msg = {
                "id": 1,
                "type": "mobile_app/push_notification_channel",
                "webhook_id": WEBHOOK_ID,
                "support_confirm": True
            await websocket.send(json.dumps(push_channel_msg))
            print("Requested push notification channel.")
            # Listen for all incoming messages
            while True:
                data = json.loads(message)
                print("\nIncoming message:")
                print(json.dumps(data, indent=2))
                # Check if it's a push notification
                if data.get("type") == "event":
                    event_data = data.get("event", {})
                    if "message" in event_data:
                        print("✅ Push notification received:", event_data["message"])
        else:
            print("❌ Authentication failed!")
# Run
asyncio.get_event_loop().run_until_complete(connect_to_hass())
Hello Alexander Wagner:
How is local only: set. Might have something to do with it.
Hmm,
why do I need an automation, to get Homeassistant notifications?
