HASS does not turn off the groups; the log tells me:
2020-12-21 21:53:14 ERROR (MainThread) [homeassistant.components.homeassistant] homeassistant.turn_off cannot be called without a target
hass --script check_config -c ... cant find anything. I checked the docs (see here for example: Home Assistant Core Integration - Home Assistant).
Can’t I use homeassistant.turn_off in a script? It’s not mentioned anywhere as far as I have seen…
Another question: When do I have to use “data:”? Sometimes it’s there in the docs another time it’s not.
Hint: All groups exist an do have entities in it. The groups are read only in the UI-configurator, because the do not have a unique_id. Perhaps its related.
Tried this. No output to the log and HASS does nothing. In the original config posted above, the mediaplayers stopped. When the script came to the homassistant.turn_off it threw an error message about no target.
When I config a script with the UI-configurator the configurator does not show any available entites for the service homeassistant.turn_on/turn_off… I guess the problem is locate with the homeassistant domain somehow…
Most annoying: nothing in the log file even with debugging for script component activated.
Problem solved: One entity had “-” in it that i copied from the UI… “-” are not allowed, only “_”. No hint from the config checker or the debug log. But after restarting, HASS complained about not setting up the group domain. Et voila, issue was located.
So symptoms were: no entities to choose from in the UI-configurator, ambigous error “homeassistant.turn_off cannot be called without a target”, no debug output from script component, script checker did not show the error. Solution: check entity naming and especially do not use “-” in entity names.
Thanks to @anon43302295 for cleaning up my testscript, appreciated your efforts! Have a good one and thanks again.
