Homeassistant und Magic Mirror problem whith MQTT character string help
Hello, I am configuring a module for my Magic-Mirror, but I cannot get the temperature value without the entire character string of the Sonoff-Tasmota with a DHT11 temperature and humidity sensor.
I leave you an image of my problem, in case you can help me. Thanks
Magic Mirror and Tasmota_Console:
20:31:16 MQT: tele/espejo1/SENSOR = {“Time”:“2021-01-07T20:31:16”,“DHT11”:{“Temperature”:19.3,“Humidity”:26.0,“DewPoint”:-0.7},“TempUnit”:“C”}
I need to get the Temperature value only, but I don’t know how. And I’ve tried everything.
I have the module configured with MQTT (Homeassistant)
Ex Module:
//MMM-MQTTfloorplan - CON IMAGEN 3D de planta de casa !!BUENO
module: ‘MMM-MQTTfloorplan’,
position: ‘bottom_left’,
config: {
mqttServer: {
url: “IP-RASPBERY”,
user: “mqtt”,
password: “************”,
floorplan: {
image: “floorplan-default.png”,
width: 350,
height: 295,
subscriptions: [
topic: ‘stat/espejo1/RESULT’, // MQTT Topic name !
label: ‘Luz de pruebas1 - Espejo1’, // BULB OK!!
type: ‘light’,
display: { left: 120, top: 60 },
topic: ‘tele/espejo1/SENSOR’, //Work but everything  I need Only Temperature value !!!
label: ‘Espejo1 Temp’,
type: ‘label’,
display: { left: 350, top: 10},
Thank you very much for those who can help me get the temperature value, within topic:
example -> topic: ‘tele/espejo1/SENSOR’, bla…bla…bla … Help !!! ???
Happy New Year 2021 to all :wink:
issue solved thanks to the collaboration of its creator and Smart Mirror Forum
SOLVED !!!
