I made a mistake in the config file and therefore it started in “savemode”. After a few minutes the webUI was unavailabe. I was not able to login anymore. And in my router “homeassistant” as hostname was gone. It did still give the same lease.
After struggling I decided to reinstall Home Assistant, but still no luck webinterface was not available. I decided to use my other microSD card with Domoticz on it. But same problem could not access the webinterface.
If i use:
WGET local host
Resolving localhost (localhost)... ::1, 127.0.0.1
Connecting to localhost (localhost)|::1|:80... failed: Connection refused.
Connecting to localhost (localhost)|127.0.0.1|:80... failed: Connection refused.
Please help me!
sudo netstat -plnt
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 0.0.0.0:22 0.0.0.0:* LISTEN 475/sshd
tcp6 0 0 :::22 :::* LISTEN 475/sshd
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.178.51 netmask 255.255.255.0 broadcast 192.168.178.255
inet6 fe80::132e:75fb:d269:8ea1 prefixlen 64 scopeid 0x20<link>
inet6 ::b1ee:e514:a6:7105 prefixlen 64 scopeid 0x0<global>
inet6 2001:1c06:4c4:e900:6485:80cd:4bb9:29b0 prefixlen 64 scopeid 0x0<global>
ether dc:a6:32:bc:eb:59 txqueuelen 1000 (Ethernet)
RX packets 30643 bytes 9185884 (8.7 MiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 7440 bytes 906708 (885.4 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 30 bytes 1820 (1.7 KiB)
TX packets 30 bytes 1820 (1.7 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether dc:a6:32:bc:eb:5a txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
To be complete, I was adding a dahua camera in the config using Amcrest
Nobody? I really need help, nothing works
