Hi
I have problem with homebridge container on macos. My home app on iphone cannot find any accessories.
docker-compose.yaml
version: “2”
services:
home-assistant:
container_name: ha
image: homeassistant/home-assistant:latest
depends_on:
- db
links:
- db
restart: always
volumes:
- ./home-assistant:/config
ports:
- 8123:8123
env_file:
- ./home-assistant/ha.envdb:
container_name: db
image: mysql:5.7
volumes:
- ./mysql/data:/var/lib/mysql
restart: always
env_file:
- ./mysql/secrets.envhomebridge:
container_name: homebridge
image: orbnedron/homebridge-homeassistant:latest
depends_on:
- home-assistant
links:
- home-assistant
ports:
- 0.0.0.0:51862:51862
- 5353:5353/udp
volumes:
- ./homebridge:/config
restart: always
env_file:
- ./homebridge/homebridge.env
config.json
“bridge”: {
“name”: “Homebridge”,
“username”: “1C:22:3F:F3:C5:31”,
“port”: 51826,
“pin”: “012-34-567”
“platforms”: [
“platform”: “HomeAssistant”,
“name”: “HomeAssistant”,
“host”: “http://192.168.1.176:8123”,
“verify_ssl”: false,
“password”: “backa”,
“supported_types”: [
“automation”,
“binary_sensor”,
“climate”,
“cover”,
“device_tracker”,
“fan”,
“group”,
“input_boolean”,
“light”,
“lock”,
“media_player”,
“remote”,
“scene”,
“script”,
“sensor”,
“switch”,
“vacuum”
“logging”: true,
“default_visibility”: “visible”
logs:
