Some problem with HomeKit. All the entities are offline
No issues here. Have you tried another restart?
yes, ive tried. all the entity are down.
Have you configured it in config or via the integrations pane?
Via configuration.yaml.
Maybe you have a formatting issue that was forgiven in previous versions. Did you try reverting to 0.112.1 to verify that it still works there? And if it does, why don’t you post your HomeKit config to see if someone notices the problem.
with new configuration in integration the error is thisError setting up entry HASS Bridge OPYL:51831 for homekit
File “/usr/src/homeassistant/homeassistant/config_entries.py”, line 220, in async_setup
hass, self
File “/usr/src/homeassistant/homeassistant/components/homekit/init.py”, line 237, in async_setup_entry
await homekit.async_start()
File “/usr/src/homeassistant/homeassistant/components/homekit/init.py”, line 474, in async_start
(SENSOR_DOMAIN, DEVICE_CLASS_BATTERY),
File “/usr/src/homeassistant/homeassistant/helpers/entity_registry.py”, line 141, in async_get_device_class_lookup
if domain_device_class not in domain_device_classes:
TypeError: unhashable type: ‘list’
Hello I have the same problem after 112. Same error also. My first gues is the list of exclusions and inclusions I have in yaml. I would have to do some tests to be sure.
even if it is defined only
homekit:
integration does not start.
I’m making several attempts but to no avail
#homekit:
auto_start: true
# port: 51827
# port: 56332
# ip_address: 192.168.1.178
name: Home Assistant Bridge
filter:
include_domains:
- alarm_control_panel
- light
- switch
- fan
- climate
# - media_player
- lock
- sensor
- cover
- camera
include_entities:
- binary_sensor.smoke_sensor_158d00015725ea #rilevatore di fumo
- binary_sensor.natgas_sensor_158d00012ed50f #rilevatore di gas
- binary_sensor.vibration_158d0002a48eb1 #sensore vibrazione 1
- binary_sensor.vibration_158d0002a92142 #sensore vibrazione 2
- binary_sensor.water_leak_sensor_158d0002795d75 #sensore acqua cameretta
- binary_sensor.water_leak_sensor_158d0001de2ac1 #doccia water
- binary_sensor.water_leak_sensor_158d0002375cf0 #Lavandino cucina water
- binary_sensor.water_leak_sensor_158d0001d78796 #Lavandino water
- binary_sensor.water_leak_sensor_158d0001dde52c #Bagnetto Water
- binary_sensor.water_leak_sensor_158d0001d787e8 #Lavastoviglie water
- sensor.miflora_herbs10_light #luce pianta finestra cameretta
- sensor.miflora_herbs10_temperature #temperatura pianta fiestra cameretta
- sensor.miflora_herbs9_light #luce pianta finestra dx letto
- sensor.miflora_herbs9_temperature #temperatura pianta finestra dx letto
- sensor.miflora_herbs7_light #luce pianta finestra Sx letto
- sensor.miflora_herbs7_temperature #temperatura pianta finestra Sx letto
- switch.switch_air_purifier
- sensor.netatmo_la_forza_del_vento_strength
- sensor.netatmo_lo_scroscio_dell_acqua_rain
# - sensor.netatmo_lo_scroscio_dell_acqua_sum_rain_1
- sensor.netatmo_matteo_trieste_matteo_via_udine_humidity
- sensor.netatmo_matteo_trieste_matteo_via_udine_temperature
- media_player.samsung_ue48ju7500
- input_boolean.notte
- input_boolean.giorno
- input_boolean.mattina
- input_boolean.speech_notifications
- input_boolean.allarme
- input_boolean.luci_mensola
- input_boolean.luci_centrali
- input_boolean.coppa_vapore
- input_boolean.vocolinc
- input_boolean.vocolinc_profumo
- input_boolean.vocolinc_luce
- input_boolean.dispenser
- input_boolean.bianco_caldaia
- input_boolean.alba_caldaia
- input_boolean.blu_notte
- input_boolean.netatmo_led_switch
# - switch.plug_158d00021641f9 #stampanti
- sensor.miflora_herbs1_moisture #zamiocula
- sensor.miflora_herbs3_moisture #bonsai
- sensor.miflora_herbs6_moisture #finestra centrale letto
- sensor.miflora_herbs7_moisture #finestra sinistra letto
- sensor.miflora_herbs9_moisture #finestra destra camera da letto
- sensor.miflora_herbs10_moisture #finestra cameretta
- sensor.generico3_moisture #vaso metallico
- sensor.generico7_moisture #vaso sospeso tavolo
- sensor.generico6_moisture #vaso bianco dx
- sensor.generico10_moisture #vaso sospeso frigo
- sensor.generico11_moisture #vaso bianco sx
- sensor.generico5_moisture #mensola
exclude_entities:
- light.consolle_dx
- light.consolle_sx
- light.letto_castello
- switch.fritzbox_portforward_grafana3000
- switch.fritzbox_portforward_grafana8888
- switch.echo_show_di_matteo_8_shuffle_switch
- switch.echo_show_di_matteo_8_repeat_switch
- switch.echo_show_di_matteo_8_do_not_disturb_switch
- switch.alexamusic_do_not_disturb_switch
- switch.alexamusic_repeat_switch
- switch.alexamusic_shuffle_switch
- light.lampadina_consolle
- light.luci
- light.unknown_1
- switch.fritzbox_portforward_wireguard
- switch.echo_dot_di_zoltan_do_not_disturb_switch
- switch.echo_dot_di_zoltan_shuffle_switch
- switch.echo_dot_di_zoltan_repeat_switch
- switch.netatmo_led_cucina
- sensor.netatmo_matteo_trieste_camera_da_letto_co2
- sensor.netatmo_matteo_trieste_camera_da_letto_humidity
- sensor.netatmo_matteo_trieste_camera_da_letto_max_temp
- sensor.netatmo_matteo_trieste_camera_da_letto_min_temp
- sensor.netatmo_matteo_trieste_camera_da_letto_temperature
- sensor.netatmo_matteo_trieste_cameretta_co2
- sensor.netatmo_matteo_trieste_cameretta_humidity
- sensor.netatmo_matteo_trieste_cameretta_max_temp
- sensor.netatmo_matteo_trieste_cameretta_min_temp
- sensor.netatmo_matteo_trieste_cameretta_temperature
- sensor.netatmo_matteo_trieste_cucina_co2
- sensor.netatmo_matteo_trieste_cucina_humidity
- sensor.netatmo_matteo_trieste_cucina_max_temp
- sensor.netatmo_matteo_trieste_cucina_min_temp
- sensor.netatmo_matteo_trieste_cucina_temperature
# - sensor.netatmo_matteo_trieste_matteo_via_udine_humidity
- sensor.netatmo_matteo_trieste_matteo_via_udine_max_temp
- sensor.netatmo_matteo_trieste_matteo_via_udine_min_temp
# - sensor.netatmo_matteo_trieste_matteo_via_udine_temperature
- sensor.illumination_34ce008bf158
- switch.fritzbox_portforward_google_assistant_webserver
- switch.fritzbox_portforward_http_server
- switch.fritzbox_portforward_https_server
- switch.fritzbox_portforward_sftp
- switch.fritzbox_portforward_vnc
- sensor.cpu_temp
- switch.ovunque_do_not_disturb_switch
- switch.ovunque_repeat_switch
- switch.ovunque_shuffle_switch
- switch.transmission_switch
- switch.transmission_turtle_mode
- sensor.display_camera_dal_letto_humidity
- sensor.display_camera_dal_letto_temperature
# - sensor.display_cucina_battery
# - sensor.display_cucina_humidity
# - sensor.display_cucina_temperature
- sensor.bonsai_pi4_temperature
- sensor.bonsai_pi4_light_intensity
- sensor.bonsai_pi4_conductivity
- sensor.bonsai_pi4_battery
- sensor.bonsai_pi4_moisture
- sensor.zamiocula_pi4_temperature
- sensor.zamiocula_pi4_light_intensity
- sensor.zamiocula_pi4_conductivity
- sensor.zamiocula_pi4_battery
- sensor.zamiocula_pi4_moisture
- sensor.generico10_battery
- sensor.generico10_conductivity
- sensor.generico10_light_intensity
# - sensor.generico10_moisture
- sensor.generico10_temperature
- sensor.generico11_battery
- sensor.generico11_conductivity
- sensor.generico11_light_intensity
# - sensor.generico11_moisture
- sensor.generico11_temperature
- binary_sensor.miflora_herbs11_low_battery
- binary_sensor.miflora_herbs11_low_battery_2
- binary_sensor.miflora_herbs12_low_battery
- binary_sensor.miflora_herbs12_low_battery_2
- binary_sensor.miflora_herbs13_low_battery
- binary_sensor.miflora_herbs13_low_battery_2
- binary_sensor.miflora_herbs14_low_battery
- binary_sensor.miflora_herbs14_low_battery_2
- binary_sensor.miflora_herbs15_low_battery
- binary_sensor.miflora_herbs15_low_battery_2
- binary_sensor.miflora_herbs16_low_battery
- binary_sensor.miflora_herbs16_low_battery_2
- binary_sensor.miflora_herbs17_low_battery
- binary_sensor.miflora_herbs17_low_battery_2
- binary_sensor.miflora_herbs18_low_battery
- binary_sensor.miflora_herbs18_low_battery_2
- binary_sensor.miflora_herbs10_low_battery
- binary_sensor.miflora_herbs1_low_battery
- binary_sensor.miflora_herbs1_low_battery_2
- binary_sensor.miflora_herbs2_low_battery
- binary_sensor.miflora_herbs2_low_battery_2
- binary_sensor.miflora_herbs3_low_battery
- binary_sensor.miflora_herbs3_low_battery_2
- binary_sensor.miflora_herbs3_low_battery_3
- binary_sensor.miflora_herbs4_low_battery
- binary_sensor.miflora_herbs4_low_battery_2
- binary_sensor.miflora_herbs5_low_battery
- binary_sensor.miflora_herbs5_low_battery_2
- binary_sensor.miflora_herbs6_low_battery
- binary_sensor.miflora_herbs6_low_battery_2
- binary_sensor.miflora_herbs7_low_battery
- binary_sensor.miflora_herbs7_low_battery_2
- binary_sensor.miflora_herbs8_low_battery
- binary_sensor.miflora_herbs9_low_battery
- binary_sensor.miflora_herbs_low_battery
- binary_sensor.miflora_herbs_low_battery_2
- sensor.miflora1_temperature
- sensor.miflora3_temperature
- sensor.miflora9_temperature
- sensor.miflora10_temperature
# - sensor.miflora_herbs1_moisture
- sensor.miflora_herbs1_battery
- sensor.miflora_herbs1_temperature
- sensor.miflora_herbs1_conductivity
- sensor.miflora_herbs1_light
- sensor.miflora_herbs1_light_2
- sensor.miflora_herbs_light_2
- sensor.miflora_herbs2_moisture_2
- sensor.miflora_herbs2_battery_2
- sensor.miflora_herbs1_temperature_2
- sensor.miflora_herbs2_temperature_2
- sensor.miflora_herbs2_conductivity_2
- sensor.miflora_herbs2_light_2
# - sensor.miflora_herbs10_moisture
- sensor.miflora_herbs10_battery
# - sensor.miflora_herbs10_temperature
- sensor.miflora_herbs10_conductivity
# - sensor.miflora_herbs3_moisture
- sensor.miflora_herbs3_battery
- sensor.miflora_herbs3_temperature
- sensor.miflora_herbs3_conductivity
- sensor.miflora_herbs3_light
- sensor.miflora_herbs3_light_3
- sensor.miflora_herbs3_moisture_2
- sensor.miflora_herbs3_battery_2
- sensor.miflora_herbs3_temperature_2
- sensor.miflora_herbs3_temperature_3
- sensor.miflora_herbs3_conductivity_2
- sensor.miflora_herbs3_light_2
- sensor.miflora_herbs4_moisture_2
- sensor.miflora_herbs4_battery_2
- sensor.miflora_herbs4_temperature_2
- sensor.miflora_herbs4_conductivity_2
- sensor.miflora_herbs4_light_2
- sensor.miflora_herbs5_moisture
- sensor.miflora_herbs5_battery
- sensor.miflora_herbs5_temperature
- sensor.miflora_herbs5_conductivity
- sensor.miflora_herbs5_light
- sensor.miflora_herbs5_moisture_2
- sensor.miflora_herbs5_battery_2
- sensor.miflora_herbs5_temperature_2
- sensor.miflora_herbs5_conductivity_2
- sensor.miflora_herbs5_light_2
# - sensor.miflora_herbs6_moisture
- sensor.miflora_herbs6_battery
- sensor.miflora_herbs6_temperature
- sensor.miflora_herbs6_conductivity
- sensor.miflora_herbs6_light
- sensor.miflora_herbs6_moisture_2
- sensor.miflora_herbs6_battery_2
- sensor.miflora_herbs6_temperature_2
- sensor.miflora_herbs6_conductivity_2
- sensor.miflora_herbs6_light_2
# - sensor.miflora_herbs7_moisture
- sensor.miflora_herbs7_battery
# - sensor.miflora_herbs7_temperature
- sensor.miflora_herbs7_conductivity
# - sensor.miflora_herbs7_light
# - sensor.miflora_herbs9_moisture
- sensor.miflora_herbs9_battery
# - sensor.miflora_herbs9_temperature
- sensor.miflora_herbs9_conductivity
# - sensor.miflora_herbs9_light
- sensor.miflora_herbs7_moisture_2
- sensor.miflora_herbs7_battery_2
- sensor.miflora_herbs7_temperature_2
- sensor.miflora_herbs7_conductivity_2
- sensor.miflora_herbs7_light_2
- sensor.miflora_herbs8_moisture
- sensor.miflora_herbs8_battery
- sensor.miflora_herbs8_temperature
- sensor.miflora_herbs8_conductivity
- sensor.miflora_herbs8_light
- sensor.miflora_herbs_moisture
- sensor.miflora_herbs_battery
- sensor.miflora_herbs_temperature
- sensor.miflora_herbs_temperature_2
- sensor.miflora_herbs_conductivity
- sensor.miflora_herbs11_moisture
- sensor.miflora_herbs11_battery
- sensor.miflora_herbs11_temperature
- sensor.miflora_herbs11_temperature_2
- sensor.miflora_herbs11_conductivity
- sensor.miflora_herbs11_light
- sensor.miflora11_temperature
- sensor.miflora_herbs12_moisture
- sensor.miflora_herbs12_battery
- sensor.miflora_herbs12_temperature
- sensor.miflora_herbs12_temperature_2
- sensor.miflora_herbs12_conductivity
- sensor.miflora_herbs12_light
- sensor.miflora12_temperature
- sensor.miflora_herbs13_moisture
- sensor.miflora_herbs13_battery
- sensor.miflora_herbs13_temperature
- sensor.miflora_herbs13_temperature_2
- sensor.miflora_herbs13_conductivity
- sensor.miflora_herbs13_light
- sensor.miflora13_temperature
- sensor.miflora_herbs14_moisture
- sensor.miflora_herbs14_battery
- sensor.miflora_herbs14_temperature
- sensor.miflora_herbs14_temperature_2
- sensor.miflora_herbs14_conductivity
- sensor.miflora_herbs14_light
- sensor.miflora14_temperature
- sensor.miflora_herbs15_moisture
- sensor.miflora_herbs15_battery
- sensor.miflora_herbs15_temperature
- sensor.miflora_herbs15_temperature_2
- sensor.miflora_herbs15_conductivity
- sensor.miflora_herbs15_light
- sensor.miflora15_temperature
- sensor.miflora_herbs16_moisture
- sensor.miflora_herbs16_battery
- sensor.miflora_herbs16_temperature
- sensor.miflora_herbs16_temperature_2
- sensor.miflora_herbs16_conductivity
- sensor.miflora_herbs16_light
- sensor.miflora_herbs16_light_2
- sensor.miflora16_temperature
- sensor.miflora_herbs17_moisture
- sensor.miflora_herbs17_battery
- sensor.miflora_herbs17_temperature
- sensor.miflora_herbs17_temperature_2
- sensor.miflora_herbs17_conductivity
- sensor.miflora_herbs17_light
- sensor.miflora17_temperature
- sensor.miflora_herbs18_moisture
- sensor.miflora_herbs18_battery
- sensor.miflora_herbs18_temperature
- sensor.miflora_herbs18_temperature_2
- sensor.miflora_herbs18_conductivity
- sensor.miflora_herbs18_light
- sensor.miflora18_temperature
- sensor.miflora7_temperature
- sensor.miflora6_temperature
- sensor.miflora5_temperature
- sensor.display_camera_dal_letto_battery
# - switch.15344507600194d18fc1_1 # ciabatta
# - switch.15344507600194d18fc1_2 # ciabatta
# - switch.15344507600194d18fc1_3 # ciabatta
# - switch.15344507600194d18fc1_4 # ciabatta
# - switch.15344507600194d18fc1_7 # ciabatta
- switch.2883673084f3ebe9276b
- switch.2883673084f3ebe95515
- switch.2883673084f3ebe982b4
- switch.2883673084f3ebe9efe7
- switch.836742153c71bf3f8de9_1 #presa duo angela lampada computer
- switch.836742153c71bf3f8de9_2 #presa duo angela raspberry
- sensor.withings_body_temperature_c_matteo_lioi
- sensor.withings_skin_temperature_c_matteo_lioi
- sensor.withings_temperature_c_matteo_lioi
- switch.2o_echo_show_di_matteo_do_not_disturb_switch
- switch.2o_echo_show_di_matteo_repeat_switch
- switch.2o_echo_show_di_matteo_shuffle_switch
- switch.3o_echo_dot_di_matteo_shuffle_switch
- switch.3o_echo_dot_di_matteo_repeat_switch
- switch.3o_echo_dot_di_matteo_do_not_disturb_switch
- switch.matteodi_2o_fire_tv_stick_do_not_disturb_switch
- switch.matteodi_2o_fire_tv_stick_repeat_switch
- switch.matteodi_2o_fire_tv_stick_shuffle_switch
- sensor.netatmo_cucina_max_temp
- sensor.netatmo_cucina_min_temp
- sensor.netatmo_cucina_noise
- sensor.netatmo_matteo_via_udine_max_temp
- sensor.netatmo_matteo_via_udine_min_temp
- sensor.netatmo_camera_da_letto_max_temp
- sensor.netatmo_camera_da_letto_min_temp
- sensor.netatmo_cameretta_max_temp
- sensor.netatmo_cameretta_min_temp
- switch.echo_dot_di_angela_do_not_disturb_switch
- switch.echo_dot_di_angela_repeat_switch
- switch.echo_dot_di_angela_shuffle_switch
- switch.echo_dot_di_matteo_do_not_disturb_switch
- switch.echo_dot_di_matteo_repeat_switch
- switch.echo_dot_di_matteo_shuffle_switch
- switch.echo_input_di_matteo_do_not_disturb_switch
- switch.echo_input_di_matteo_repeat_switch
- switch.echo_input_di_matteo_shuffle_switch
- switch.echo_show_di_matteo_do_not_disturb_switch
- switch.echo_show_di_matteo_repeat_switch
- switch.echo_show_di_matteo_shuffle_switch
- switch.fire_tv_do_not_disturb_switch
- switch.fire_tv_repeat_switch
- switch.fire_tv_shuffle_switch
- switch.matteo_s_alexa_apps_do_not_disturb_switch
- switch.matteo_s_alexa_apps_repeat_switch
- switch.matteo_s_alexa_apps_shuffle_switch
- switch.this_device_do_not_disturb_switch
- switch.this_device_repeat_switch
- switch.this_device_shuffle_switch
- sensor.humidity_158d0000fd72e9
- sensor.xiaomi_cooker_temperature
- sensor.temperature_158d0000fd72e9
- sensor.generico3_battery
- sensor.generico3_conductivity
- sensor.generico3_light_intensity
# - sensor.generico3_temperature
- sensor.generico4_battery
- sensor.generico4_conductivity
- sensor.generico4_light_intensity
- sensor.generico4_moisture
- sensor.generico4_temperature
- sensor.generico5_battery
- sensor.generico5_conductivity
- sensor.generico5_light_intensity
# - sensor.generico5_moisture
- sensor.generico5_temperature
- sensor.generico6_battery
- sensor.generico6_conductivity
- sensor.generico6_light_intensity
# - sensor.generico6_moisture
- sensor.generico6_temperature
- sensor.generico7_battery
- sensor.generico7_conductivity
- sensor.generico7_light_intensity
# - sensor.generico7_moisture
- sensor.generico7_temperature
- sensor.temperature_158d00027866df
- sensor.temperature_158d0000fd7048
- sensor.humidity_158d0000fd7048
- sensor.humidity_158d00027866df
- sensor.temperature_158d0000fc0915
- sensor.humidity_158d0000fc0915
- sensor.temperature_158d0001081601
- sensor.humidity_158d0001081601
- sensor.temperature_158d0000fd4b6c
- sensor.humidity_158d0000fd4b6c
- sensor.pressure_158d0002b54708
# - sensor.temperature_158d0002b54708 temperatura esterna cucina
- sensor.humidity_158d0002b54708
- sensor.temperature_158d0000f4200c
- sensor.humidity_158d0000f4200c
- sensor.temperature_158d0000edbf0c
- sensor.humidity_158d0000edbf0c
- switch.meliconi
- switch.samsung
- switch.tv_program
- switch.source
- switch.ok
- switch.yamaha
- switch.tv_volume
- switch.tv_mute
- switch.plug_158d00010e1932
- switch.gateway_aqara_switch
- sensor.netatmo_camera_da_letto_co2
- sensor.netatmo_camera_da_letto_humidity
- sensor.netatmo_camera_da_letto_temperature
- sensor.netatmo_cameretta_co2
- sensor.netatmo_cameretta_temperature
- sensor.netatmo_cucina_co2
- sensor.netatmo_cucina_humidity
- sensor.netatmo_cucina_pressure
- sensor.netatmo_cucina_temperature
- sensor.netatmo_cucina_wifi
- sensor.netatmo_la_forza_del_vento_angle
- sensor.netatmo_la_forza_del_vento_gust_angle
- sensor.netatmo_la_forza_del_vento_gust_strength
# - sensor.netatmo_la_forza_del_vento_strength
- sensor.netatmo_lo_scroscio_dell_acqua_battery
# - sensor.netatmo_lo_scroscio_dell_acqua_rain
- sensor.netatmo_lo_scroscio_dell_acqua_sum_rain_24
# - sensor.netatmo_matteo_via_udine_humidity
# - sensor.netatmo_matteo_via_udine_temperature
- sensor.netatmo_cameretta_humidity
- switch.plug_158d0000fa991c
# - switch.plug_158d00010ed740 #zephir
# - switch.mixer_remote
- switch.mixer_remote_usb
# - remote.mi_remote_bagno
# - remote.mi_remote_letto
- switch.raspberry_tv_camera_usb
# - switch.raspberry_tv_camera
# - remote.mi_remote_bagnetto
# - switch.luce_piante
# - switch.luce_pianta_sotto_caldaia
# - switch.luce_frigo
# - switch.luce_finestra_pianta
- switch.lavatrice
- switch.lavastoviglie
- switch.frigo
- switch.osmc_salone
- switch.dietpikodi
# - switch.plug_158d00013e6275 #electroline
- switch.videoproiettore_camera
- switch.videoproiettore_camera_usb
- switch.box_musica
- switch.ciabatta
- switch.netatmo_led_cucina_usb
- switch.raspberry_natale_usb
- sensor.weather_dewpoint_temperature
- sensor.weather_temperature
- switch.switch_a_rf433
- switch.switch_b_rf433
- switch.switch_d_rf433
- sensor.cpu_temperature
- light.tradfri_bulb
- light.tradfri_bulb_2
- light.tradfri_bulb_3
- light.tradfri_bulb_4
- light.tradfri_bulb_5
- light.tradfri_bulb_6
- light.tradfri_bulb_7
- light.tradfri_bulb_8
- light.tradfri_driver
- light.dispensa_caffe
- light.tradfri_driver_2
- sensor.mensola_light_intensity
- sensor.mensola_temperature
- sensor.vasofrigo_light_intensity
- sensor.vasofrigo_temperature
- sensor.bonsai_light_intensity
- sensor.bonsai_temperature
- sensor.finestradestra_light_intensity
- sensor.finestradestra_temperature
- sensor.zamiocula_light_intensity
- sensor.zamiocula_temperature
- sensor.illumination_158d0001d5c666
- sensor.illumination_286c07891747
- sensor.illumination_34ce0088adac
- sensor.illumination_7811dcb2142e
- sensor.illumination_7c49eb1bcd8a
- sensor.illumination_f0b4299a4613
- climate.netatmo_cameretta_2
- climate.netatmo_camera_da_letto_2
- climate.netatmo_cucina_2
- climate.netatmo_salone_2
# - climate.netatmo_camera_da_letto
# - climate.netatmo_cameretta
# - climate.netatmo_cucina
# - climate.netatmo_salone
- sensor.weather_cloudiness
- sensor.weather_fog
- sensor.weather_high_clouds
- sensor.weather_humidity
- sensor.weather_low_clouds
- sensor.weather_medium_clouds
- sensor.weather_precipitation
- sensor.weather_pressure
- sensor.weather_symbol
- sensor.weather_wind_direction
- sensor.weather_wind_speed
- sensor.dark_sky_apparent_temperature
- sensor.dark_sky_daily_summary
- sensor.dark_sky_daytime_high_temperature_1d
- sensor.dark_sky_daytime_high_temperature_2d
- sensor.dark_sky_daytime_high_temperature_3d
- sensor.dark_sky_daytime_high_temperature_4d
- sensor.dark_sky_daytime_high_temperature_5d
- sensor.dark_sky_daytime_high_temperature_6d
- sensor.dark_sky_daytime_high_temperature_7d
- sensor.dark_sky_hourly_summary
- sensor.dark_sky_hourly_summary_tmpl
- sensor.dark_sky_humidity
- sensor.dark_sky_humidity_1d
- sensor.dark_sky_humidity_2d
- sensor.dark_sky_humidity_3d
- sensor.dark_sky_humidity_4d
- sensor.dark_sky_humidity_5d
- sensor.dark_sky_humidity_6d
- sensor.dark_sky_humidity_7d
- sensor.dark_sky_icon
- sensor.dark_sky_icon_1d
- sensor.dark_sky_icon_2d
- sensor.dark_sky_icon_3d
- sensor.dark_sky_icon_4d
- sensor.dark_sky_icon_5d
- sensor.dark_sky_icon_6d
- sensor.dark_sky_icon_7d
- sensor.dark_sky_overnight_low_temperature_1d
- sensor.dark_sky_overnight_low_temperature_2d
- sensor.dark_sky_overnight_low_temperature_3d
- sensor.dark_sky_overnight_low_temperature_4d
- sensor.dark_sky_overnight_low_temperature_5d
- sensor.dark_sky_overnight_low_temperature_6d
- sensor.dark_sky_overnight_low_temperature_7d
- sensor.dark_sky_precip_intensity
- sensor.dark_sky_precip_intensity_1d
- sensor.dark_sky_precip_intensity_2d
- sensor.dark_sky_precip_intensity_3d
- sensor.dark_sky_precip_intensity_4d
- sensor.dark_sky_precip_intensity_5d
- sensor.dark_sky_precip_intensity_6d
- sensor.dark_sky_precip_intensity_7d
- sensor.dark_sky_precip_probability
- sensor.dark_sky_precip_probability_1d
- sensor.dark_sky_precip_probability_2d
- sensor.dark_sky_precip_probability_3d
- sensor.dark_sky_precip_probability_4d
- sensor.dark_sky_precip_probability_5d
- sensor.dark_sky_precip_probability_6d
- sensor.dark_sky_precip_probability_7d
- sensor.dark_sky_pressure
- sensor.dark_sky_pressure_1d
- sensor.dark_sky_pressure_2d
- sensor.dark_sky_pressure_3d
- sensor.dark_sky_pressure_4d
- sensor.dark_sky_pressure_5d
- sensor.dark_sky_pressure_6d
- sensor.dark_sky_pressure_7d
- sensor.dark_sky_summary
- sensor.dark_sky_summary_1d
- sensor.dark_sky_summary_2d
- sensor.dark_sky_summary_3d
- sensor.dark_sky_summary_4d
- sensor.dark_sky_summary_5d
- sensor.dark_sky_summary_6d
- sensor.dark_sky_summary_7d
- sensor.dark_sky_summary_tmpl
- sensor.dark_sky_temperature
- sensor.dark_sky_wind_bearing
- sensor.dark_sky_wind_bearing_1d
- sensor.dark_sky_wind_bearing_2d
- sensor.dark_sky_wind_bearing_3d
- sensor.dark_sky_wind_bearing_4d
- sensor.dark_sky_wind_bearing_5d
- sensor.dark_sky_wind_bearing_6d
- sensor.dark_sky_wind_bearing_7d
- sensor.dark_sky_wind_dir
- sensor.dark_sky_wind_speed
- sensor.dark_sky_wind_speed_1d
- sensor.dark_sky_wind_speed_2d
- sensor.dark_sky_wind_speed_3d
- sensor.dark_sky_wind_speed_4d
- sensor.dark_sky_wind_speed_5d
- sensor.dark_sky_wind_speed_6d
- sensor.dark_sky_wind_speed_7d
- sensor.data_e_ora
- sensor.date
- sensor.date_2
- sensor.date_time
- sensor.illumination_158d0001d5c7f8
- sensor.illumination_158d0001d5c81f
- sensor.illumination_158d0001d6afcf
- sensor.illumination_158d0001d6b01c
- sensor.illumination_158d0001d6b24c
- sensor.illumination_158d0002236b7e
- sensor.illumination_158d000224fa65
- sensor.illumination_158d0001656f8f
- sensor.playroom_fan_humidity
- sensor.playroom_fan_temperature
- sensor.ciabatta_temperature
- sensor.electroline_temperature
- sensor.netatmo_led_cucina_temperature
- sensor.raspberry_tv_camera_temperature
- sensor.telecomando_camera_letto_temperature
- sensor.telecomando_videoproiettore_camera_temperature
- sensor.smappee_casa_matteo_water_sensor_humidity
- sensor.smappee_casa_matteo_water_sensor_temperature
- climate.electroline
- climate.zephir
- light.gateway_light_34ce008bf158
- sensor.mixer_temperature
Wow. You have A LOT of devices in HomeKit. Not sure how many you have there, but there is a limit of 200 devices per bridge. You might try using the new HomeKit Bridge integration rather than hard coding in your config. You could set up multiple bridges, splitting your devices by domain in order to lessen the number of devices per bridge.
Ignore that last comment. I didn’t realize you have most of your devices in an Exclude. Even so, you might still want to try the HomeKit Bridge integration. Or at least simplify your config by excluding entire switch and sensor domains, and then include only the devices you want in HomeKit. That might cut down on the giant laundry list of excluded devices.
