Note that HomeKit accessories can only be paired to one device at once. If your device is currently paired with Siri, you will need to reset it in order to pair it with Home Assistant. Once Home Assistant is configured to work with the device, you can export it back to Siri with the HomeKit component.
I have both pieces of this working. I have some HA accessories exposed to Homekit and usable in the Home app. I have some HomeKit accessories exposed to HA and usable.
The problem I’m having is getting HomeKit accessories, which are working with HA, to then also be exposed back to Homekit for use in the Home app.
Example:
Switch 1 (HA MQTT)
Switch 2 (HA HomeKit)
Both switches work in HA.
Switch 1 shows up in the Home app, but Switch 2 does not.
I have my HomeKit component set up to start with a delay (to wait for the zwave network to come up). I believe this should also be providing ample time for the HomeKit controller to get set up and expose the devices.
@Jon123 You could enable debug logging for both, but I’m not sure how far you can go with it. It seems like your delay is too short so the homekit component can’t add it.
Yes, but admittedly I’m also very very behind on updating HA. Still on 0.73. Haven’t had the time to dedicate to do the update given all the breaking changes that have happened since then - need to put aside a few hours to deal with it.
If you’re not waiting on zwave, it may be some other problem. But you should still be able to delay the homekit starting up, just change the automation’s trigger to:
