The Problem
If you’ve got a complex HomeKit setup and want to migrate to Home Assistant, you hit a wall immediately:
- Apple hides automation logic. The
HMShortcutActionAPI returns only a name — nothing about the conditional logic, device actions, or workflow inside. Controllers for HomeKit, Eve, all the third-party apps — they all see the same opaque object. - No export feature exists. Apple provides zero way to export automations from the Home app.
- Manual migration is brutal. You’re rewriting automations by hand, scene by scene, automation by automation.
This is especially painful if you’ve built complex “Convert to Shortcut” automations with if/then/else logic — that data just looks like a wall you can’t read.
The Solution
homekit-extractor bypasses Apple’s API limitations by combining two extraction methods:
Method 1: Mac Catalyst App
A native SwiftUI app that exports everything the public API does expose:
- All accessories with full metadata
- Rooms, zones, and scenes
- All automations and their trigger/condition data
- Marks shortcut automations (but can’t see inside them)
Method 2: homed Database Extraction (the breakthrough)
A Python script that reads Apple’s internal HomeKit daemon database (~/Library/HomeKit/core.sqlite) and extracts:
- The full Shortcuts workflow definitions — all your if/then/else blocks
- Device actions inside shortcuts — every light turn-on, lock unlock, etc.
- Conditional logic — toggle patterns, multi-branch menus, nested conditions
The trick: Apple’s homed daemon stores everything in a CoreData SQLite database, encoded in binary plists and protobuf. Three layers deep, but all decodable with Python stdlib.
Method 3: Automated Home Assistant Conversion
Combine both exports and convert everything to HA automation YAML automatically:
- Entity mapping from HomeKit accessory names to HA entity IDs
- Characteristic translation (brightness, color, temperature → HA service calls)
- Conditional logic preservation
- Occupancy and “party mode” conditions
What You Get
A merged JSON export with every automation fully decoded, then converted to Home Assistant YAML.
Real-world example: I extracted 207 HomeKit automations, mapped 272 accessories to HA, and converted 177 of them to working HA automations with 1,964 service calls — automations that previously looked like a black box.
Quick Start
Prerequisites
- Mac with HomeKit configured (on the same iCloud account as your Home)
- Xcode 15+ and XcodeGen
- Python 3.9+ (stdlib only — no pip packages)
- Full Disk Access granted to Terminal (System Settings > Privacy & Security)
Steps
Build & run the Catalyst app:
cd app xcodegen generate open HomeKitDumper.xcodeproj # Build & Run (Cmd+R) for "My Mac (Designed for iPad)" # Click "Export HomeKit Data" → homekit_export.json -
Extract the homed database:
cd scripts python3 homed_extract.py -o homekit_homed_export.json -
Merge both exports:
python3 merge_exports.py \ --app-export ../homekit_export.json \ --homed-export homekit_homed_export.json \ -o homekit_merged.json -
Convert to Home Assistant (optional):
# Copy your HA entity registry first # (/config/.storage/core.entity_registry from your HA instance) python3 homekit_to_ha.py \ --export homekit_merged.json \ --entity-registry core.entity_registry \ -o homekit_automations.yaml
Then paste the YAML into your automations and tweak as needed.
Key Limitations
- Read-only — This extracts data, doesn’t write it back to HomeKit
- macOS only — The homed database is only on macOS. (The Catalyst app works on both.)
- Full Disk Access required — The database is TCC-protected
- Protobuf UUIDs can’t be resolved — Device references inside shortcuts use an isolated UUID namespace, so the script falls back to name-based matching
- Local data only — Reads your Mac’s database copy. If your Home Hub hasn’t synced recently, data may be stale.
Documentation
Full details in the repo:
- SCHEMA.md — Complete homed database schema
- DISCOVERY.md — How I reverse-engineered the homed approach
- CONVERSION.md — Conversion logic & HomeKit ↔ HA mapping
Privacy & Security
Everything runs locally. No network calls, no telemetry, no credentials. The homed database is opened read-only. Scrub your export before sharing (it contains device names, rooms, and automation logic).
GitHub
github.com/tamengual/homekit-extractor
License: MIT
Have a complex HomeKit setup you’re migrating to HA? This tool should handle it. If you hit edge cases or want to contribute (better UUID resolution, iOS extraction, more workflow action types), issues and PRs welcome.
