If the cache is clear, custom_header removed, kiosk mode installed and my 3.6 theme folder it should work automatically.
@msmykalov did you update browser mod and cleared your cache after updating? Also make sure you only have one instance of HA running on the same device. E.g. if you open 2 browser windows, it will trigger the popup on the windows that was seen as latest active. I am working on a fix for device ids.
this is probably because you have multiple windows open (or havenât cleared cache).
Close everything to be sure, then open an incognito window, then try the popup. If it still doesnât work please check the following:
make sure you have the latest version of browser_mod
make sure you have the latest version of HKI (3.6.0, you can see this in the about section in the menu)
If it still doesnât work, Iâd suggest reinstalling the update (just get the update from my repo and do a copy/replace on all files, get the update file not the actual release )
If that still doesnât work I will suggest waiting till I find a fix. But it really should work
to be absolutely sure, close every single lovelace session you have (also on e.g. your phone, tablet, tv or whatever). Device_id this isnât working properly atm so this is a temporary fix. If that still doesnât work, I will suggest downgrading browser_mod to 2.3.0 I believe and then download the button templates from HKI 3.5.3 (can be found in the releases on my repo). If I remember correctly nothing really changed except for those device_idâs.
For the people wondering when I will ever start working on the footer again I have some great news, some people asked me why there was no footer (though there is one in the screenshots).
We know that Maykar has stopped development of CH, but thanks to a few great devs like Thomas Loven and KTibow a footer is possible again albeit in a slight different style.
Cleared cache on both Android app and browser (even tried another browser).
Issue seems to persist. Incognito mode on Chrome also shows the double header.
Everything is up to date.
Homekit Infused 3.6.1
*Welcome back precious footer
Changes:
The great return of the footer navigation bar
Views can now be added to the footer (read documentation on the repo, go to the addon_list for docs)
The header margins have been slightly adjusted so it would look better on desktops and better in conjunction with the new footer
The subtitle in the header has its functionality reset and will no longer act as a home/menu button, it will now trigger the all notifications popup like it always used to do
Double tapping the subtitle in the header will now take you to the HA Settings page for quicker access
Kiosk mode has been removed in favor of the method used in 3.5.3 (read the breaking changes below)
Removed unused files
Bugfixes and slight speed improvements
BREAKING CHANGES (this ONLY applies to people coming from 3.6.0!):
In favor of having a footer again I had to remove kiosk mode since that will also hide the tab bar, this change will undo the breaking change in the previous version (and will also make the header disappear again on other lovelace dashboards). Fortunately, this time that bar will now simply be a footer and will work on other dashboards (that do not have a footer). It will not work nice with dwains dashboard! So make sure you REMOVE kiosk mode from HACS!!!
Notes:
Do NEVER update past the latest compatible HA version if you donât want HKI to break. You can find the latest compatible version either on this repo or in the HA Settings (accessible through the HKI menu).
The newest beta breaks HKI and it requires lovelace_gen to get updated by its developer. I have no say in this and I have no ETA as to when this will be possible!
Tips:
The next HA version will forbid the use of !secrets on any other file than configuration.yaml and your main lovelace file. Needless to say, this doesnât work in split files. If you happen to have a split configuration I will suggest preparing for this change by removing all the secrets you might find in your config. If you really rely on !secrets then move the necessary config into configuration.yaml since that file is not affected by this change.
How to update:
I will first stress out that you will have to make a backup of your current setup (as you should always do).
Drag and drop all the files into the root of your Home Assistant setup (the paths must match so if you have done it right it will ask you to overwrite files, click yes and the update is complete) Now restart your Home Assistant.
Hi Jim, thatâs not 100% correct. You can use secrets in all files that are included in configuration.yaml as well, meaning you can continue splitting the config with packages etc.
The issue lies with integrations that load other yaml files, just as lovelace_gen does.
That sounds like an issue then. For me it worked fine when I commented out lovelace_gen (for which there is a PR from petro, which I didnât test yet).
