@Djal could you for now replace line 46 and replace the word state_not to state?
That way it will render nothing (since that state doesnât exist) and there are no other cards configured.
It would be like if you had no notifications at all, the problem is, if you delete all notifications it will throw an error that at least 1 card needs to be configured.
Try that please and reload lovelace afterwards. Next up, best to restart HA to be sure and then open your home assistant instance in an incognito windows (to make sure cache isnât the problem).
thxs for answering. you mean for my last message right? or for the t.setconfig error?
Indendation error will still going on even after changing the line 46 .
EDIT: line 46 edited, HA restarted. t.setconfig error seems to be gone, at least on my several browser. except on the ios app itâs still going. (even after ios restart)
Homekit Infused 3.6.2
*Fixes, Footer and more Fixes!
Changes:
The footer can now be enabled/disabled (great for when using multiple dashboards)
Fixed an issue where the footer would show mirrored text on other dashboards
The footer can now have itâs icon direction changed (icons can now start either from the right or left side, ideal for left/right handed modes)
Hiding the footer text should allow for more visible icons when using more than just the 2 pre-programmed icons
The footer text can now be either the date, time, logged in user or completely hidden
Person and Custom views can now be added to the footer (thanks to @deNicola)
Footer icons can now be changed
All the new footer options (with exception of the icons) are instant and can be accessed through the HKI Settings in the UI
Changed the default menu item (this would look bad with the footer turned off, since the sidebar uses the same icon)
Fixed an issue where setting the alarm wouldnât work at all since last update (both in lovelace, and in automations since both were affected by this error)
Compatible with the upcoming HA version, READ THE BREAKING CHANGES BELOW (thanks to @petro for the fixes and @burningstone for mentioning them to me)
Fixed an issue where the HKI Settings view would not scroll down far enough to select the themes all the way down in the dropdown menu (this might still be an issue for small phones, for them I will suggest editing the themes on a larger screen)
Updated my personal repo for all up-to-date examples
Numerous other small Bugfixes
BREAKING CHANGES:
The footer is now off by default, to enable it enter the HKI Settings and enable it!
The following file has had changes and will overwrite the one you have, if you have made changes to that file, please note that you will have to do them again! /homekit-infused/user/config/footer_config/yaml
Lovelace_gen has been edited and is for the time being not up to date on HACS. If you just did a full copy/replace from the update you wonât need to worry about this, if you did each file manually then make sure you replace the following file with the one from the update package. /custom_components/lovelace_gen/__init__.py
WARNING: This might not work with the current HA, this file is meant for the upcoming 2021.4.x version. If your HA doesnât load after this update, please reinstall lovelace_gen. When 2021.4 releases you can safely copy and replace this file!
Notes:
Please visit the following page to find out all the new stuff you can do with the footer (as well as some warnings when using it with multiple dashboards) Footer Documentation
How to update:
I will first stress out that you will have to make a backup of your current setup (as you should always do).
Drag and drop all the files into the root of your Home Assistant setup (the paths must match so if you have done it right it will ask you to overwrite files, click yes and the update is complete) Now restart your Home Assistant.
Is there any chance for a video tutorial for setting up the basics of your excellent work?
The reason for asking is that Iâm new to HA, but not new to computers or basic coding, and the HA general framework/how it interacts with different parts of it self is âcumbersomeâ to say at least.
Iâm willing to buy you, or anyone else for that matter, a coffee if this could be done =)
Well I might have time for a video tutorial soon. I wonât promise anything since I have promised this in the past and some people are waiting for videoâs ever since I had released V2 which is over a year back
Keep an eye on this channel for videoâs but I will get to them soon.
The footer has been renamed and is now called navigation_bar
The navigation_bar has new options, you can now choose between header, footer or off, when set as header it will act like the standard HA header but with the sweet options that you can already select in HKI, this is persistent on ALL other dashboards. So if you want a clock in the navigation bar on your other dashboard? Well just enable it here
The menu can now be hidden from the navigation_bar (warning, this will make navigation extremely hard if you donât replace it with your own buttons). The menu button is enabled by default.
Fixed alignment of text when icons were set on the left side (this affected date and username) and should now look the way it should.
On other dashboards with a single view and with the HKI navigation bar enabled will now hide the title
Note from previous release: The about view has been updated and had all its links fixed, you can now open a FR/Issue from the app again
Other small fixes
BREAKING CHANGES:
The footer has been renamed to navigation_bar, the navigation_bar and its options have been reset, if you did make changes you will have to do them again. You can safely remove the following file after updating homekit-infused/user/config/footer_config.yaml To enable the footer again go to the HKI Settings.
REMINDER: If you have installed one of the last few updates you might have found that it included the following file custom_components/lovelace_gen/__init__.py. Do NOT use this file if you are using HA 2021.3.x or lower! This file only works for newer versions like HA 2021.4.x. The component was included so that people that are running the beta can still enjoy HKI. When 2021.4.x releases this week make sure you copy this file since without this modified lovelace_gen file HKI will NOT load on newer versions!
How to update:
Like the update and the choice we have about using the footer navigation bar.
I still have a strange issue. If I want to disable the Navigation Bar entirely, I still see the bar at the top. See image 1/2. Also, since update 3.6.0 I have some weird automatic layout weirdness. See image 3. Anyone have any clue?
@marvandorth Hmm, the layout should be right as nothing has changed on that department. else try redownloading my layout-card file from my repo (donât install layout-card in HACS!!!). Remember to ABSOLUTELY clear cache afterwards, as cache is a b*tch.
If you turn âoffâ the navigation bar, it will become the default navigation bar that is included in HA core, no changes, no styling just plain olâ nav bar as was intended by the HA team. This is particularly useful when you have troubles running multiple dashboards. Hiding the bar is currently not possible and done for multiple reasons, which the most important is that when treated wrong, there wont be any navigation at all. This is to prevent unwanted user error.
The latest version of HKI has an updated lovelace_gen component. Donât forget to replace yours with this file when you update to Home Assistant 2021.4.x or above!
It doesnât matter if you do it before or after the HA update, just remember to restart Home Assistant after you have replaced the file and donât forget to clear your cache!
I have the HKI installed. But I can not get a grip on how to add lights or temperature cardsâŚ
Where can i add these? Is HKI only editable through yaml-code? No GUI?
No GUI unfortunately, its basically meant to customize yourself just like normal lovelace in YAML mode.
You will have to use any of the addons on the list for this to work. Note that the current auto fill templates will all be deprecated in the upcoming version. Though that might take weeks. You can find examples on my personal repo on how to add addons on your views and since I dont use autofill myself this will remain true even after the update.
However the upcoming version will have easy mode available. It can do full automatic view filling! Almost no configuration required and no install of addon cards from my repo is needed in the upcoming version. (Though experienced users can still use it!)
Thanks Jimmy for your continued hard work!
ive just upgraded from 3.5.3 into 3.6.3 and followed the upgrade instructions.
seems that the navigation bar is missing even though its configured in the HKI settings.
Any idea or direction where to lookup?
