Homekit Infused (HKI) v2.0.0 Release Candidate (Beta 11) - Updated 31/05/2020
Tags: #<Tag:0x00007f73ad0aba18>
@pergola.fabio
Edit: though you’d miss out on all the new features like a super easy to setup interface. Personalised day/night cycle. Make changes without the need to restart. Scrolling notifications. Device counters and the ability to assign any type of entity as a badge inside of buttons. Easily create a frontpage layout with the built-in edit mode. Automatic creation of automations, battery and scenes views (no config required). Addons created by the community (you can find beautiful addons created by @noodlemctwoodle here ). You will get perks like easy updating with usually only a few folders to replace. You’ll get custom views and custom areas on existing views in where you can create either fully customised views/cards or use the preinstalled widgets which can all be setup in the UI any of the code used in those custom areas will survive all future updates! You will even get a notification if there is an update and you can check the current version against the latest within the UI. The best of it all is that every change made in the UI is instant and in realtime (you could even open a second browser to see it happen). And many other great improvements.
Settings Screen:
Edit mode (used to setup a frontpage layout):
About screen to show if you have updates (hacs updates will also be shown here in the future):
Or what about an easy vacuum control?
Or homekit style climate controls?
Homekit style popups:
And for all this all you’d need to do is the initial installation. Setting it up is the easy part!
its fixed in new declutter version
For everyone following this thread, Custom Header has finally been fixed. This means I can move forward getting HKI 2.0.0 ready for a public release. This will be released in the upcoming weeks. For those that can’t wait can still download the current beta. The current beta will get an update beginning next week which will make HKI compatible with HA 0.110.x.
Current beta testers can simply update to the public version. No need to reinstall like was the case with releases prior to 2.0.0. If you are still running beta 1 to 7 I will urge you to update to beta 10. Read the release notes of each patch to be sure you get all the new config. Most beta’s can be easily updated with the exception of going from beta 7 to beta 10 (it requires slightly more work, trust me not too much :rofl:).
Thanks all for the patience as this project has been in beta for quite some time now. Videos and instructions on how to install will follow after the release. The current betas are pretty well documented and you should not have any trouble installing this.
Cheers
Hi @jimz011 since we can have multiple dashboards is it possible to switch between HKI and my current one or will everything be overwritten?
It will be possible. You can either have a storage (ui controlled lovelace) or a yaml dashboard. HKI can run as second dashboard (it is currently also the default setting).
Keep an eye on the docs which I will change soon on how to do this.
Great, looking forward to it!
Hello jimz011
just started with HA a month ago and your HKI was big inspiration to start, its really nice layout =)
still just play with standard HA to learn it before i wanna move to HKI.
been looking on your github code for hki, but couldnt figure what card are you using to create that picture, home status, battery and mail?
i made home status with a “Picture Entity Card”, but not sure how i can get those icons you have in left/right side with battery status and such :smiley:
can you point me in right direction to what i need to use to do so?
It is actually a picture elements card.
Maybe this will help?
yes that was perfect thank you so much :smiley: also made me need to learn picture-elements :smiley: guess that will be usefull later when doing a floorplan =)
Well thank you, because of your question I have found errors in that card. Haha. Well good luck and don’t forget to join our discord channel (see link in first post).
kind of been out of the loop for awhile, but just noticed my pop-ups don’t open the card anymore, just a blank pop-up on safari and iOS, but seems to work on chrome (desktop only)… still on v1 but did I miss something breaking the cards? (mostly dbuits and the ones you modified previously I believe)
It kinda depends on how long “out of the loop” is haha. It hasn’t been updated in a while so I did not make any changes there. However when this card first emerged it did change quite a lot so yeah that might be the problem. It did break as far as I know and you might need to check the code for changes.
Release Candidate of HKI 2.0.0 (Beta 11)
Changes:
  • HKI is now fully compatible with HA 0.110.x
  • Revised French, Romanian, Italian, Hebrew and Spanish language (this adds vacuum and cover translations, English and Dutch are already available, more languages will follow)
  • Added Polish language (thanks to @donhimol)
  • Fixed bug where changing the language would not reset the attached input_boolean after an error
  • Fixed bug where changing the icon set would not reset the attached input_boolean after an error
  • Fixed bug where the header and/or header subtitle could not be hidden.
  • Added missing header boolean for the covers view.
  • Added cover switch popup
  • Fans on the climate view now show a spinning icon when turned on and now shows a blue color
  • Media Player widget is now an option (fill in the media_players in the room config), this is currently limited to simple media players, I will add functionality to this in upcoming versions.
  • A Google Home widget is now added to the media player view
  • Custom Header has been fixed (please update it via HACS and clear cache). You can now set HKI to be your main dashboard again. As a result the workaround has been removed!
  • Storage mode is now included, the default dashboard and you can create your own dashboards with the Home Assistant interface just like you would without HKI. To have HKI as your main dashboard go to the sidebar and select the preferred dashboard, which is user based.
  • New users that have created an entire dashboard with the lovelace UI editor will be pleased to know that installing HKI will not overwrite anything, nor will you lose access to that dashboard.
  • As a result of the above resources are no longer included in the HKI package, you will have to install them yourself through HACS. After installing an addon it will ask you to add the resources automatically. If you have already installed the addons all you would need to do is add the resources (I suggest you keep the current resource file as a backup which can be found in dashboards/resources as you can quickly copy/paste it into the UI that way). To add resources to Home Assistant go to the Home Assistant Configuration menu and select Lovelace Dashboards. There will then be a tab that says Resources.
  • Your own resources can now be used and will not be overwritten by HKI updates.
  • Fixed an issue where badges on buttons would not update after a change.
  • The Room Config settings will now only show config for the amount of rooms selected per floor (this to avoid rooms not being loaded at startup, please check the room config and add/change your settings if needed)
  • You can now select the amount of floors shown in the lights and devices view. Invoke edit mode to change how it looks or hide it entirely.
  • All groups in HKI Settings > Room Config are now working. The views will no longer get its entities from device_counters.yaml. This file is still needed for counting the number of devices that are ‘on’ so you won’t need to make any changes here. This will also pave the way for a room based view which is highly requested. Make sure you fill in all the blanks in room config and add your cameras in the new camera config view. Remember, your config will no longer come from the extra_settings.yaml file and you MUST fill in the HKI Settings > Room Config for the views to work properly.
  • HKI Settings has 2 new options: Google Home and Cameras
  • Border radius has returned to the theme settings view and can now be set in the ui again. You can safely remove user_content/theme_settings/border-radius.yaml. To use the variable border-radius inside of your custom cards use the following style variable: `border-radius: {{ states(‘input_select.border_radius_selector’) }};
  • Fixed missing custom buttons (the settings would say there are 8 buttons to configure, but 3 were missing)
  • Bugfixes and small enhancements to the code. Cleaned up some of the unused includes.
For more information on how to install/update please visit the link below.
There is an error in the latest beta, please remove /dashboards/homekit-infused/remote.yaml to fix it
So just finally got around to looking into this, not sure if you remember how the old pop-ups were setup but it was vertical-stack, swipe-card, entities, pop-up… just removing that first vertical stack it’s all good again. Must have been one of the front-end changes made recently. Thanks!
EDIT: (The old vertical stack was probably from the original pop-up from before Dbuits card…)
what should be done, if i am doing it for first time.
how to configure?
thanks
Do you plan to make the code lighter so HKI would run on RPi?
I will definitely try to make it lighter, but in its current state this will never run smooth on a rpi (the reason for this is pretty simple: it uses a lot of input text entities which weigh heavy on the backend side).
The project was never made with a pi in mind simply because they are too weak imho (anyone that has used a pi and switched to something better will probably acknowledge this). The main reason it is so heavy is because everything done inside HKI is instant (e.g. adding a light to the frontend will not require a restart, nor will you need to add the light to a group in yaml) this is true for almost every setting within HKI. All changes are always instant and you could even open 2 browser windows to see it change in realtime.
Removing this heavy form of templating will make it lighter though would also make it harder to configure (like 1.1 and 0.13.3 was) it would then also require restarts after most of the changes whereas now you could leave it running forever (unless you really have to add something like automations and such).
The goal of this project was to make something simple to setup but most of all even simpler to use. I am improving the projects code but it might take a while to slim down 60k lines of code. Also I wanted to mention that if people are serious about smart homes that they should not run it on a pi (that is my own personal opinion ofc). As that little machine is the heart and brains of your smarthome. I see it often that people spend hundreds if not thousands of euros on smarthome products but only spend 50 euros on the most important piece. It feels like driving a ferrari with an opel kadett engine or running a GTX2080ti on a pentium 4 (if you get what I mean).
In other news though, I am currently learning to create Android apps and maybe in the future I will create a native app for HKI instead (which would definitely run on a rpi as the serving side).
This is awesome, thank you for sharing your work!
Im just getting started and have a few questions I havent been able to find answers too…
  • I am currently using Home Assistant Supervised in docker, It is at 111.4, I see in the instructtions to use 110.4, how can I downgrade to 110.4?
  • Ive filled out the device_counters yaml so far, when I move to config rooms I select 1 floor 9 rooms, but then it looks like it starts at “room 11”? Also, can I add more than one entity per line? So for lights can I put ‘light.living_room_lights, light.strips’ for example? (see image below)
  • The home page shows me an error for the swipe card, Ive verified its installed and loaded in lovelace, even reinstalled it. It looks from the error like maybe i need to add more config? (see image below)
Thanks!
