I can’t get the Homekit component to setup/install correctly. It fails with an error. The only action i’ve taken is added the line for homekit:
to my configuration.yaml
per the instructions in the docs.
Running v0.109.6 in Docker
Can anyone decipher this error?
Here is the full error message:
Logger: homeassistant.setup
Source: components/homekit/accessories.py:329
First occurred: 7:27:40 PM (1 occurrences)
Last logged: 7:27:40 PM
Error during setup of component homekit
File "/usr/local/lib/python3.7/socketserver.py", line 452, in __init__
self.server_bind()
File "/usr/local/lib/python3.7/http/server.py", line 137, in server_bind
socketserver.TCPServer.server_bind(self)
File "/usr/local/lib/python3.7/socketserver.py", line 466, in server_bind
self.socket.bind(self.server_address)
OSError: [Errno 98] Address in use
File "/usr/src/homeassistant/homeassistant/setup.py", line 171, in _async_setup_component
hass, processed_config
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 170, in async_setup
await hass.async_add_executor_job(homekit.setup)
File "/usr/src/homeassistant/homeassistant/components/homekit/__init__.py", line 374, in setup
interface_choice=self._interface_choice,
File "/usr/src/homeassistant/homeassistant/components/homekit/accessories.py", line 329, in __init__
super().__init__(**kwargs)
File "/usr/local/lib/python3.7/site-packages/pyhap/accessory_driver.py", line 220, in __init__
self.http_server = HAPServer(network_tuple, self)
File "/usr/local/lib/python3.7/site-packages/pyhap/hap_server.py", line 840, in __init__
super(HAPServer, self).__init__(addr_port, handler_type)
File "/usr/local/lib/python3.7/socketserver.py", line 455, in __init__
self.server_close()
File "/usr/local/lib/python3.7/site-packages/pyhap/hap_server.py", line 911, in server_close
for sock in list(self.connections.values()):
AttributeError: 'HAPServer' object has no attribute 'connections'
