Homekit support for a newbie
Hi all,
I just installed Homekit integration using yaml following integration documentation.
There are some points that I did not understanding and need some clarification. I’m referring to the consideration on ACCESSORY ID and PERSISTENCE STORAGE.
What I get is that is suggested to create storage information for all those entities that will be used in Homekit right?
And I get that in case some entity is not as at boot this will be removed from Homekit. But I don’t understand if the remove is temporary or permanent.
In case it is permanent does it means that I have to redo all the integration config again?
And my final question. I added Homekit using my iPhone and all the entities configures are showing also on my old iPad. But status on this device is always not respond. Why?
Thank in advance to all
