Ok, here is the log. Just some mentions:
- There is a bluethoot switch connected to homeassistant homekit (also eve)
- If I factory reset the Eve Motion I can add it to homeassistant homekit as blue tooth device as well
- If I add the Eve Motion to the home app (Apple) and remove it from then this happens (exception)
2022-10-19 15:07:24.322 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Starting HomeKit controller update: 60:2A:FD:A9:D1:E7
2022-10-19 15:07:24.322 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Called async_set_available_state with True for 60:2A:FD:A9:D1:E7
2022-10-19 15:07:24.322 DEBUG (MainThread) [aiohomekit.controller.ip.connection] 192.168.2.35: raw request: b’GET /characteristics?id=4.10,4.9,2.10,3.10,2.9,3.9,4.11,2.11,3.11 HTTP/1.1\r\nHost: 192.168.2.35\r\n\r\n’
2022-10-19 15:07:25.240 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Starting HomeKit controller update: 59:93:B4:E9:E3:E6
2022-10-19 15:07:25.240 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Called async_set_available_state with True for 59:93:B4:E9:E3:E6
2022-10-19 15:07:25.240 DEBUG (MainThread) [aiohomekit.controller.ip.connection] 192.168.2.58: raw request: b’GET /characteristics?id=2.2068,1.37,1.34,3.65,1.49,1.52,3.3088,4.4112,3.3094,1.18,4.4118,1.76,1.21,1.24,2.2064,2.2070,1.27,1.33,1.39,1.36,1.51,1.54,3.3084,4.4108,3.3093,1.66,2.65,4.4117,1.75,1.20,2.2060,1.17,1.23,2.2069,1.35,1.38,4.65,1.41,1.50,1.53,1.65,4.4116,3.3092,1.19,1.25,1.22 HTTP/1.1\r\nHost: 192.168.2.58\r\n\r\n’
2022-10-19 15:07:25.442 DEBUG (MainThread) [aiohomekit.controller.ip.connection] 192.168.2.58: raw response: bytearray(b’{“characteristics”:[{“aid”:2,“iid”:2068,“value”:2},{“aid”:1,“iid”:37,“value”:26.7},{“aid”:1,“iid”:34,“value”:18.3},{“aid”:3,“iid”:65,“value”:0},{“aid”:1,“iid”:49,“value”:1},{“aid”:1,“iid”:52,“value”:100},{“aid”:3,“iid”:3088,“value”:26.9},{“aid”:4,“iid”:4112,“value”:26.3},{“aid”:3,“iid”:3094,“value”:0},{“aid”:1,“iid”:18,“value”:3},{“aid”:4,“iid”:4118,“value”:0},{“aid”:1,“iid”:76,“value”:0},{“aid”:1,“iid”:21,“value”:1},{“aid”:1,“iid”:24,“value”:32.0},{“aid”:2,“iid”:2064,“value”:28.7},{“aid”:2,“iid”:2070,“value”:0},{“aid”:1,“iid”:27,“value”:“East Ecobee”},{“aid”:1,“iid”:33,“value”:0},{“aid”:1,“iid”:39,“value”:25.6},{“aid”:1,“iid”:36,“value”:15.6},{“aid”:1,“iid”:51,“value”:0},{“aid”:1,“iid”:54,“value”:“The Hive is humming along. You have no pending alerts or reminders.”},{“aid”:3,“iid”:3084,“value”:0},{“aid”:4,“iid”:4108,“value”:0},{“aid”:3,“iid”:3093,“value”:100},{“aid”:1,“iid”:66,“value”:0},{“aid”:2,“iid”:65,“value”:0},{“aid”:4,“iid”:4117,“value”:100},{“aid”:1,“iid”:75,“value”:1},{“aid”:1,“iid”:20,“value”:22.5},{“aid”:2,“iid”:2060,“value”:0},{“aid”:1,“iid”:17,“value”:0},{“aid”:1,“iid”:23,“value”:18.3},{“aid”:2,“iid”:2069,“value”:100},{“aid”:1,“iid”:35,“value”:26.7},{“aid”:1,“iid”:38,“value”:18.3},{“aid”:4,“iid”:65,“value”:0},{“aid”:1,“iid”:41,“value”:“2014-01-03T00:00:00-07:00T”},{“aid”:1,“iid”:50,“value”:0},{“aid”:1,“iid”:53,“value”:0},{“aid”:1,“iid”:65,“value”:0},{“aid”:4,“iid”:4116,“value”:2},{“aid”:3,“iid”:3092,“value”:2},{“aid”:1,“iid”:19,“value”:26.7},{“aid”:1,“iid”:25,“value”:36.0},{“aid”:1,“iid”:22,“value”:26.7}]}’)
2022-10-19 15:07:25.443 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Called async_set_available_state with True for 59:93:B4:E9:E3:E6
2022-10-19 15:07:25.445 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Finished HomeKit controller update: 59:93:B4:E9:E3:E6
2022-10-19 15:07:25.815 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room_tv, old_state=<state media_player.living_room_tv=playing; volume_level=1.0, is_volume_muted=False, media_position=160.336, media_position_updated_at=2022-10-19T15:07:15.806989-07:00, app_id=AndroidNativeApp, app_name=Netflix, entity_picture_local=None, friendly_name=Living Room TV, supported_features=152509 @ 2022-10-19T15:05:23.684260-07:00>, new_state=<state media_player.living_room_tv=playing; volume_level=1.0, is_volume_muted=False, media_position=170.341, media_position_updated_at=2022-10-19T15:07:25.814585-07:00, app_id=AndroidNativeApp, app_name=Netflix, entity_picture_local=None, friendly_name=Living Room TV, supported_features=152509 @ 2022-10-19T15:05:23.684260-07:00>>
2022-10-19 15:07:26.223 DEBUG (MainThread) [aiohomekit.controller.ip.connection] 192.168.2.35: raw response: bytearray(b’{“characteristics”:[{“aid”:4,“iid”:10,“value”:1},{“aid”:4,“iid”:9,“value”:1},{“aid”:2,“iid”:10,“value”:1},{“aid”:3,“iid”:10,“value”:1},{“aid”:2,“iid”:9,“value”:1},{“aid”:3,“iid”:9,“value”:1},{“aid”:4,“iid”:11,“value”:false},{“aid”:2,“iid”:11,“value”:false},{“aid”:3,“iid”:11,“value”:false}]}’)
2022-10-19 15:07:26.223 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Called async_set_available_state with True for 60:2A:FD:A9:D1:E7
2022-10-19 15:07:26.224 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Finished HomeKit controller update: 60:2A:FD:A9:D1:E7
2022-10-19 15:07:26.600 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch 00B9 [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Session closed callback: rssi=-88
2022-10-19 15:07:26.732 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Starting HomeKit controller update: C9:48:70:46:07:42
2022-10-19 15:07:26.732 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Called async_set_available_state with True for C9:48:70:46:07:42
2022-10-19 15:07:26.732 DEBUG (MainThread) [aiohomekit.controller.ip.connection] 192.168.2.55: raw request: b’GET /characteristics?id=2.2068,1.37,1.34,3.65,1.49,1.52,3.3088,4.4112,3.3094,1.18,4.4118,1.76,1.21,1.24,2.2064,2.2070,1.27,1.33,1.39,1.36,1.51,1.54,3.3084,4.4108,3.3093,1.66,2.65,4.4117,1.75,1.20,2.2060,1.17,1.23,2.2069,1.35,1.38,4.65,1.41,1.50,1.53,1.65,4.4116,3.3092,1.19,1.25,1.22 HTTP/1.1\r\nHost: 192.168.2.55\r\n\r\n’
2022-10-19 15:07:27.523 DEBUG (MainThread) [aiohomekit.controller.ip.connection] 192.168.2.55: raw response: bytearray(b’{“characteristics”:[{“aid”:2,“iid”:2068,“value”:2},{“aid”:1,“iid”:37,“value”:26.7},{“aid”:1,“iid”:34,“value”:22.8},{“aid”:3,“iid”:65,“value”:0},{“aid”:1,“iid”:49,“value”:1},{“aid”:1,“iid”:52,“value”:0},{“aid”:3,“iid”:3088,“value”:23.8},{“aid”:4,“iid”:4112,“value”:27.9},{“aid”:3,“iid”:3094,“value”:0},{“aid”:1,“iid”:18,“value”:3},{“aid”:4,“iid”:4118,“value”:0},{“aid”:1,“iid”:76,“value”:2},{“aid”:1,“iid”:21,“value”:1},{“aid”:1,“iid”:24,“value”:42.0},{“aid”:2,“iid”:2064,“value”:28.4},{“aid”:2,“iid”:2070,“value”:0},{“aid”:1,“iid”:27,“value”:“West Ecobee”},{“aid”:1,“iid”:33,“value”:0},{“aid”:1,“iid”:39,“value”:25.6},{“aid”:1,“iid”:36,“value”:15.6},{“aid”:1,“iid”:51,“value”:0},{“aid”:1,“iid”:54,“value”:“The Hive is humming along. You have no pending alerts or reminders.”},{“aid”:3,“iid”:3084,“value”:0},{“aid”:4,“iid”:4108,“value”:0},{“aid”:3,“iid”:3093,“value”:100},{“aid”:1,“iid”:66,“value”:1},{“aid”:2,“iid”:65,“value”:0},{“aid”:4,“iid”:4117,“value”:100},{“aid”:1,“iid”:75,“value”:1},{“aid”:1,“iid”:20,“value”:24.7},{“aid”:2,“iid”:2060,“value”:0},{“aid”:1,“iid”:17,“value”:2},{“aid”:1,“iid”:23,“value”:22.8},{“aid”:2,“iid”:2069,“value”:100},{“aid”:1,“iid”:35,“value”:26.7},{“aid”:1,“iid”:38,“value”:21.1},{“aid”:4,“iid”:65,“value”:0},{“aid”:1,“iid”:41,“value”:“2035-01-03T00:00:00-07:00T”},{“aid”:1,“iid”:50,“value”:0},{“aid”:1,“iid”:53,“value”:100},{“aid”:1,“iid”:65,“value”:1},{“aid”:4,“iid”:4116,“value”:2},{“aid”:3,“iid”:3092,“value”:2},{“aid”:1,“iid”:19,“value”:27.1},{“aid”:1,“iid”:25,“value”:36.0},{“aid”:1,“iid”:22,“value”:26.7}]}’)
2022-10-19 15:07:27.523 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Called async_set_available_state with True for C9:48:70:46:07:42
2022-10-19 15:07:27.526 DEBUG (MainThread) [homeassistant.components.homekit_controller.connection] Finished HomeKit controller update: C9:48:70:46:07:42
2022-10-19 15:07:31.029 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch 00B9 [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Connected, processing subscriptions: set(); rssi=-88
2022-10-19 15:07:31.454 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=switch.plug_3, old_state=<state switch.plug_3=on; linkquality=63, friendly_name=Plug 3 @ 2022-10-19T15:07:18.342395-07:00>, new_state=<state switch.plug_3=on; linkquality=60, friendly_name=Plug 3 @ 2022-10-19T15:07:18.342395-07:00>>
2022-10-19 15:07:31.524 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch 00B9 [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:07:31.524 DEBUG (MainThread) [aiohomekit.controller.abstract] Eve Light Switch 00B9 [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:07:32.152 DEBUG (MainThread) [aiohomekit.protocol.tlv] sending [
6 (State): (1 bytes/<class ‘bytearray’>) 0x01
3 (PublicKey): (32 bytes/<class ‘bytes’>) b’v3\x93\xd9\xf3\xb3Bm\xc7~<*\xf0p\x1d\xd4f\xc0Gh\xb5\xbaXd\xf6s\xf4\x85\x1c\xfd\xc9/’
2022-10-19 15:07:32.152 DEBUG (MainThread) [aiohomekit.controller.ble.client] Queuing fragment for write: b’\x00\x02 \x0e\x00*\x00\t\x01\x01\x01%\x06\x01\x01\x03 v3\x93\xd9\xf3\xb3Bm\xc7~<*\xf0p\x1d\xd4f\xc0Gh\xb5\xbaXd\xf6s\xf4\x85\x1c\xfd\xc9/’
2022-10-19 15:07:33.458 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Session closed callback: rssi=-88
2022-10-19 15:07:33.461 DEBUG (MainThread) [aiohomekit.controller.ble.client] Bleak error calling <function BlePairing._async_populate_accessories_state at 0x7f84faaf8280>, retrying…
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 76, in _async_wrap
return await func(*args, **kwargs)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/pairing.py”, line 546, in _async_populate_accessories_state
await self._populate_accessories_and_characteristics(force_update)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/pairing.py”, line 577, in _populate_accessories_and_characteristics
await self._async_pair_verify()
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/pairing.py”, line 359, in _async_pair_verify
session_id, derive = await drive_pairing_state_machine(
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 258, in drive_pairing_state_machine
decoded = await _pairing_char_write(client, char, iid, request)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 212, in _pairing_char_write
data = await char_write(client, None, None, handle, iid, next_write)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 195, in char_write
pdu_status, data = await ble_request(
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 101, in ble_request
return await _read_pdu(client, decryption_key, handle, tid)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/ble/client.py”, line 137, in _read_pdu
data = await client.read_gatt_char(handle)
File “/usr/local/lib/python3.10/site-packages/bleak/init.py”, line 482, in read_gatt_char
return await self._backend.read_gatt_char(char_specifier, **kwargs)
File “/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/client.py”, line 601, in read_gatt_char
assert_reply(reply)
File “/usr/local/lib/python3.10/site-packages/bleak/backends/bluezdbus/utils.py”, line 22, in assert_reply
raise BleakDBusError(reply.error_name, reply.body)
bleak.exc.BleakDBusError: [org.bluez.Error.Failed] Operation failed with ATT error: 0x0e (Unlikely Error)
2022-10-19 15:07:35.820 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room_tv, old_state=<state media_player.living_room_tv=playing; volume_level=1.0, is_volume_muted=False, media_position=170.341, media_position_updated_at=2022-10-19T15:07:25.814585-07:00, app_id=AndroidNativeApp, app_name=Netflix, entity_picture_local=None, friendly_name=Living Room TV, supported_features=152509 @ 2022-10-19T15:05:23.684260-07:00>, new_state=<state media_player.living_room_tv=playing; volume_level=1.0, is_volume_muted=False, media_position=180.346, media_position_updated_at=2022-10-19T15:07:35.819371-07:00, app_id=AndroidNativeApp, app_name=Netflix, entity_picture_local=None, friendly_name=Living Room TV, supported_features=152509 @ 2022-10-19T15:05:23.684260-07:00>>
2022-10-19 15:07:36.702 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Session closed callback: rssi=-88
2022-10-19 15:07:36.702 WARNING (MainThread) [bleak.backends.bluezdbus.client] Failed to cancel connection (/org/bluez/hci0/dev_D9_36_73_B9_6E_62):
2022-10-19 15:07:40.107 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Session closed callback: rssi=-88
2022-10-19 15:07:40.319 DEBUG (MainThread) [aiohomekit.controller.ble.controller] Discovery for hkid 76:9F:A0:C8:8C:55 not found, waiting for advertisement with timeout: 30.0
2022-10-19 15:07:40.328 DEBUG (MainThread) [aiohomekit.controller.coap.connection] Pair setup 1/2 uri=coap://[fd26:c05a:68bf:0:74f8:c711:660d:76c3]:5683/1
2022-10-19 15:07:40.328 DEBUG (MainThread) [aiohomekit.protocol] #1 ios → accessory: send SRP start request
2022-10-19 15:07:40.328 DEBUG (MainThread) [aiohomekit.protocol.tlv] sending [
0 (Method): (1 bytes/<class ‘bytearray’>) 0x00
2022-10-19 15:07:40.330 ERROR (MainThread) [coap] Error received and ignored in this codepath: [Errno 101] Network unreachable
2022-10-19 15:07:43.131 INFO (MainThread) [coap] Retransmission, Message ID: 21155.
2022-10-19 15:07:43.131 ERROR (MainThread) [coap] Error received and ignored in this codepath: [Errno 101] Network unreachable
2022-10-19 15:07:48.733 INFO (MainThread) [coap] Retransmission, Message ID: 21155.
2022-10-19 15:07:48.734 ERROR (MainThread) [coap] Error received and ignored in this codepath: [Errno 101] Network unreachable
2022-10-19 15:07:49.028 INFO (SyncWorker_0) [homeassistant.components.command_line.switch] Running state value command: ssh -i /config/ssh/hass_rsa -o StrictHostKeyChecking=no [email protected] /usr/sbin/frigg_webfilter status
2022-10-19 15:07:49.333 INFO (SyncWorker_5) [homeassistant.components.command_line.switch] Running state value command: ssh -i /config/ssh/hass_rsa -o StrictHostKeyChecking=no [email protected] /usr/sbin/frigg_webfilter status
2022-10-19 15:07:49.512 INFO (SyncWorker_17) [homeassistant.components.command_line.switch] Running state value command: ssh -i /config/ssh/hass_rsa -o StrictHostKeyChecking=no [email protected] /usr/sbin/frigg_webfilter status
2022-10-19 15:07:49.980 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Session closed callback: rssi=-88
2022-10-19 15:07:55.234 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:07:55.235 DEBUG (MainThread) [aiohomekit.controller.abstract] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:07:56.329 WARNING (MainThread) [aiohomekit.controller.coap.connection] Pair setup 1/2 failed!
2022-10-19 15:07:56.332 ERROR (MainThread) [homeassistant.components.homekit_controller.config_flow] Pairing attempt failed with an unhandled exception
File “/usr/local/lib/python3.10/asyncio/tasks.py”, line 456, in wait_for
return fut.result()
asyncio.exceptions.CancelledError
File “/usr/src/homeassistant/homeassistant/components/homekit_controller/config_flow.py”, line 479, in async_step_pair
self.finish_pairing = await discovery.async_start_pairing(self.hkid)
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/coap/discovery.py”, line 57, in async_start_pairing
salt, srpB = await self.connection.do_pair_setup(
File “/usr/local/lib/python3.10/site-packages/aiohomekit/controller/coap/connection.py”, line 283, in do_pair_setup
response = await asyncio.wait_for(
File “/usr/local/lib/python3.10/asyncio/tasks.py”, line 458, in wait_for
raise exceptions.TimeoutError() from exc
asyncio.exceptions.TimeoutError
2022-10-19 15:07:57.993 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch 00B9 [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:07:57.993 DEBUG (MainThread) [aiohomekit.controller.abstract] Eve Light Switch 00B9 [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:07:58.846 DEBUG (MainThread) [aiohomekit.protocol.tlv] sending [
3 (PublicKey): (32 bytes/<class ‘bytes’>) b’>R<\x0fs\x1cZ\x85\xdf\x00-W\t1\x06"\x1ea\xc4V\x8c\xaf\xab\x1a7\xc8\x95\x93\x05Z\xccM’
2022-10-19 15:07:58.846 DEBUG (MainThread) [aiohomekit.controller.ble.client] Queuing fragment for write: b’\x00\x02\xa0\x0e\x00*\x00\t\x01\x01\x01%\x06\x01\x01\x03 >R<\x0fs\x1cZ\x85\xdf\x00-W\t1\x06"\x1ea\xc4V\x8c\xaf\xab\x1a7\xc8\x95\x93\x05Z\xccM’
2022-10-19 15:07:59.761 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Session closed callback: rssi=-88
2022-10-19 15:08:06.628 DEBUG (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: entity_id=media_player.living_room_tv, old_state=<state media_player.living_room_tv=playing; volume_level=1.0, is_volume_muted=False, media_position=201.144, media_position_updated_at=2022-10-19T15:07:56.617129-07:00, app_id=AndroidNativeApp, app_name=Netflix, entity_picture_local=None, friendly_name=Living Room TV, supported_features=152509 @ 2022-10-19T15:05:23.684260-07:00>, new_state=<state media_player.living_room_tv=playing; volume_level=1.0, is_volume_muted=False, media_position=211.154, media_position_updated_at=2022-10-19T15:08:06.627853-07:00, app_id=AndroidNativeApp, app_name=Netflix, entity_picture_local=None, friendly_name=Living Room TV, supported_features=152509 @ 2022-10-19T15:05:23.684260-07:00>>
2022-10-19 15:08:07.277 DEBUG (MainThread) [aiohomekit.controller.ble.controller] Discovery for hkid 76:9F:A0:C8:8C:55 not found, waiting for advertisement with timeout: 30.0
2022-10-19 15:08:07.278 DEBUG (MainThread) [aiohomekit.controller.coap.connection] Pair setup 1/2 uri=coap://[fd26:c05a:68bf:0:74f8:c711:660d:76c3]:5683/1
2022-10-19 15:08:07.278 DEBUG (MainThread) [aiohomekit.protocol] #1 ios → accessory: send SRP start request
2022-10-19 15:08:07.278 DEBUG (MainThread) [aiohomekit.protocol.tlv] sending [
2022-10-19 15:08:07.280 ERROR (MainThread) [coap] Error received and ignored in this codepath: [Errno 101] Network unreachable
2022-10-19 15:08:08.653 DEBUG (MainThread) [aiohomekit.controller.ble.pairing] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:08:08.653 DEBUG (MainThread) [aiohomekit.controller.abstract] Eve Light Switch [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Description updated: old=HomeKitAdvertisement(name=‘Eve Light Switch’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111) new=HomeKitAdvertisement(name=‘Eve Light Switch 00B9’, id=‘9d:6e:fe:b3:27:4e’, status_flags=<StatusFlags.0: 0>, config_num=1, category=<Categories.SWITCH: 8>, setup_hash=b’\xc5$\x8aH’, address=‘D9:36:73:B9:6E:62’, state_num=111)
2022-10-19 15:08:09.769 DEBUG (MainThread) [aiohomekit.controller.abstract] Eve Light Switch 00B9 [D9:36:73:B9:6E:62] (id=9D:6E:FE:B3:27:4E): Accessories cache loaded (c#: 1)
2022-10-19 15:08:10.127 INFO (MainThread) [coap] Retransmission, Message ID: 1855.
2022-10-19 15:08:10.127 ERROR (MainThread) [coap] Error received and ignored in this codepath: [Errno 101] Network unreachable
2022-10-19 15:08:15.821 INFO (MainThread) [coap] Retransmission, Message ID: 1855.
2022-10-19 15:08:15.821 ERROR (MainThread) [coap] Error received and ignored in this codepath: [Errno 101] Network unreachable
