i have an Issue with Home Assisant + HomeKit + ZigBee.
I have several Zigbee Plugs and Lights and when i turn them on/off in HomeKit, they turn on/off as they should, but after a second they turn on/off again but only in HomeKit and the Plug/Light itself will not turn on/off again, it just shows it as on/off in HomeKit…
When i turn them on/off in HomeAssistant the problem will not appear, Home Assistant shows them as on/off instantly.
I’m using ZigBee2mqtt.
Did anyone have the same issue and is there a solution?
I am also having exactly the same issue and would be interested in a fix. My observations are:
It seemed to start after I have upgraded to iOS 15, or possibly after upgrading my ATV to the latest TVOS, however I have tried disabling the ATV and the problem remains.
My iPhone and AW are affected, my Macbook appears unaffected
HomeAssistant can control devices fine
I tried creating a new Bridge in the HK integration, this was also affected
I am facing the exact same issue since I upgraded my devices to iOS 15. I am pretty sure that the iOS update is the reason for this since all devices which are still on iOS 14 don‘t have that issue. Also the Macbook acts normal.
Also a clean install of my iOS devices didn‘t help.
Would be great if someone could help to fix this very annoying problem.
