Hassio 209
Homematic USB device
Dear all,
I have a problem with the setup of the Homematic within Home Assistant. After intallation of the Homematic addon and setup cannot change anything in the webgui of homematic. Sections not reachable or changes will not be saved.
HA log extract:
‘2020-03-19 20:47:43 WARNING (SyncWorker_0) [pyhomematic._hm] Failed to initialize proxy
2020-03-19 20:47:44 WARNING (SyncWorker_0) [pyhomematic._hm] Failed to initialize proxy
2020-03-19 20:47:44 ERROR (SyncWorker_2) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: <urlopen error [Errno 111] Connection refused>
2020-03-19 20:47:44 WARNING (SyncWorker_2) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:47:44 WARNING (MainThread) [homeassistant.components.mqtt] Data in your configuration entry is going to override your configuration.yaml: {‘broker’: ‘192.168.178.99’, ‘discovery’: False, ‘password’: ‘mqtt’, ‘port’: 1883, ‘username’: ‘server’}
2020-03-19 20:48:15 ERROR (SyncWorker_7) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:48:15 WARNING (SyncWorker_7) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:48:46 ERROR (SyncWorker_5) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:48:46 WARNING (SyncWorker_5) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:49:17 ERROR (SyncWorker_9) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:49:17 WARNING (SyncWorker_9) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:49:48 ERROR (SyncWorker_4) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:49:48 WARNING (SyncWorker_4) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:50:19 ERROR (SyncWorker_16) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:50:19 WARNING (SyncWorker_16) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:50:50 ERROR (SyncWorker_15) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:50:50 WARNING (SyncWorker_15) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:51:21 ERROR (SyncWorker_18) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:51:21 WARNING (SyncWorker_18) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:51:52 ERROR (SyncWorker_11) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:51:52 WARNING (SyncWorker_11) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:52:23 ERROR (SyncWorker_1) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:52:23 WARNING (SyncWorker_1) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:52:54 ERROR (SyncWorker_4) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:52:54 WARNING (SyncWorker_4) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:53:25 ERROR (SyncWorker_6) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:53:25 WARNING (SyncWorker_6) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.
2020-03-19 20:53:56 ERROR (SyncWorker_15) [pyhomematic._hm] RPCFunctions.jsonRpcPost: Exception: HTTP Error 404: Not Found
2020-03-19 20:53:56 WARNING (SyncWorker_15) [pyhomematic._hm] ServerThread.jsonRpcLogin: Unable to open session.’
20-03-19 19:47:49 ERROR (MainThread) [supervisor.homeassistant] Error on call http://172.30.32.1:8123/api/: Cannot connect to host 172.30.32.1:8123 ssl:None [Connection refused]
log extract of homematic:
‘2020-03-19 20:50:00,508 [ERROR] BidCosRpcDispatcher - Could not register BidCos-RF_java’
configration.yaml
homematic:
interfaces:
rf:
host: 192.168.178.99
resolvenames: json
username: homematic
password: homematic
wired:
port: 2000
resolvenames: json
username: homematic
password: homematic
ip:
port: 2010
hosts:
ccu2:
username: homematic
password: homematic
