I have the Max! thermostats and a Max! cube to control them, but like many others here I have issues with the cube forgetting it’s configuration often… I’d like to resolve this before winter!
After some investigation I found that the cube can be re-flashed with CUL firmware very easily, which turns it to a generic RF device as far as I can tell…
This can then be used with Homematic software to pair the thermostats with the newly flashed cube, and then the homematic component can be used to add the devices to Home Assistant.
Has anyone already managed to get this working ? - I searched and found some old posts, but it seems there is now a homematic addon for hassio, so I’m hoping it may not be too hard!
Interested to know if anyone attempted / succeeded with this approach, or if anyone with Homematic experience can spot any error in my intended plan ? (I’ve not used Homematic before!)
