I have installed several HomeMatic HmIP-FBL blind actuators. If I want to close the blind and the tilt position is set to something other than 0%, the blind will not close completely.
So I have to explicitly set the tilt position to 0 before I can close the blind. The same behavior applies when opening the blinds. I need to set the tilt position to 100 before I can open the blinds.
This behavior makes it more complicated to carry out a simple control in scripts because I always have to fire a close_cover_tilt first and afterwords a close_cover.
Wouldn’t it be easier if a close_cover_tilt were triggered automatically before a close_cover (if the actuator is able to control the tilt position)?
Is there any easier way to open or close the blinds completely? Or do I miss something?
