Being new to HA, I am trying to figure out how it works so please bear with me After installing and playing with HA bit, I have the following:
- Hue bridge (5 lamps, but bridge not paired with HA)
- Sonos (connected to HA and working, happened through UI in the „integrations“ section)
- Zigbee2MQTT (connects to cc2531 and is paired with 1 hue bulb. HA discovered the Hue bulb successfully and created a switch in the States UI)
- Mosquitto (used by HA and Zigbee2MQTT)
- Homematic CCU2 (configured via yaml and all the sensors etc are visible in the states UI and switches etc were created automatically)
In the UI under Configuration -> Devices, I can see the the auto-discovered stuff only: Hue bulb via Zigbee2MQTT and the Sonos stuff. None of the Homematic stuff is visible there. Also ther Homematic component does not list in the integration page.
Can someone shed some light on why this is the case?
