Hi everyone,
thanks for your work.
As I can see so far, there is no support for the Homematic IP Keypad. At least the battery level would be really nice, to see, when it’s low on power.
Thanks so much
If you are using the HoneMatic Local integration, then your request should be made on the integrations GitHub page.
If you are using the official HoneMatic integration, then switch to HoneMatic Local.
