Homematic (IP) Local integration does not work after Update from last week
Hi all,
Please don’t complain about insufficient information, I’m still quite new to Home Assistant and am not fully familiar with it yet.
About 2-3 weeks ago, I installed and set up the “Homematic (IP) Local” integration.
I created a dashboard, and everything was working fine.
Then, last week, I did the updates that were pending in Home Assistant. (Unfortunately, I’m not sure exactly what was included.)
Today, I wanted to check on things and found that the Homematic (IP) Local integration seems to no longer be working.
For all sensors, I now only get “Entity not available”.
I can’t find the Homematic (IP) Local integration in Home Assistant anymore, and it’s not being offered for reinstallation either. Now, there is only a “Homematic” integration, but I can’t install it via the GUI.
Regards Sven
First - clear your browser cache completely.
Second - restart the entire system, not just HA core.
Third - What does the logs say?
still same after hard reboot.
You need to add it from HACS first.
If I try to add it from Hacs I got following message:
ha3
The installation i’ve done three weeks ago was via GUI.
And the Intregration was called “Homematic (IP) Local”
like Wally says. .You’ll need a download in HACS for this integration become available ( again)
which will get you:
did not know what happend, but until now this integration was not shown by hacs store. tried to add repo again → repo already exits → look up for homemativ (ip)local again → now its available…
Probably some caching result. dont think too much on it, unless it happens again.
